查看: 1964|回复: 0
SL1588H降压芯片36V降压5V2A同步降压IC
发表于 2022-8-22 14:37:55 | 显示全部楼层 |阅读模式
关键词: DC-DC , 降压恒压 , 电源芯片
General Description
The SL158 8 H a low EMI signature, asynchronous, step-down, switch-mode converter with internal power MOSFETs.
It offers a very compact solution to provide a 2A continuous current over a wide input supply range, with excellent load
and line regulation. S L158 achieves low EMI signature with well controlLED switching edges. Fault condition
protection includes programmable-output over-voltage protection, Constant on time Mode, and thermal shutdown.
SL158 8 H requires a minimal number of readily available standard external components. It is available in SOT23-6 package.
Features
• Wide 4.5V to 36V Operating Input Range
• 2.0A Continuous Output Current
• 500KHz Switching Frequency
• Short Protection with Hiccup-Mode
• Built-in Over Current Limit
• Programmable Output Over-Voltage Protection
• DCM Mode for High Efficiency in Light Load
• Integrated internal Soft-Start
• 120/80mΩ Low RDS(ON) Internal MOSFETs
• Output Adjustable from 0.6V
• Low EMI Signature
• 99% Duty cycle
• Integrated internal compensation
• Thermal Shutdown
• Available in SOT23-6 Package
• Constant on time Mode
Applications
• Automotive Entertainment
• Wireless and DSL modems
• Computer Entertainment
• Power Supply for Car Chargers
Typical Application Circuit
