SL4007 大功率升压恒压芯片 2.8-24V输入 输出ADJ
发布时间:2021-8-26 14:19    发布者:小郑
关键词: 电源IC , DC-DC升压恒压IC , 电源
General Description
  The SL4007 is boost topology switching regulator for wide operating voltage applications. It
provides built-in gate driver pin for driving external N-MOSFET. The non-inverting input of error
amplifier connects to a 1.2V precision reference voltage. It has programmable switching frequency set
by external resistor, and programmable inductor peak current limit connects a resistor from CS to GND.
Current mode control and external compensation network make is easy and flexible to stabilize the
system.
  The SL4007 is available in the small footprint SOP-8L(EP) package to fit in space-saving PCB
layout for application fields.
Features
 Start-up Voltage: 2.8V
 Wide Supply Voltage Operating Range: 5V to 24V
 Precision Feedback Reference Voltage: 1.2V (±2%)
 Shutdown Current: <3μA
 Programmable Switching Frequency: 100KHz~1000KHz
 Input Under Voltage Protection(UVP)
 Switching MOSFET Over Current Protection (OCP)
 Over Temperature Protection (OTP)
 Package: SOP-8L(EP)
Applications
 Chargers
LCD Displays
 Handheld Devices
 Portable Products
 Power Bank
Typical Application Circuit
本文地址:https://www.eechina.com/thread-773135-1-1.html     【打印本页】
