MAXON qca9880 MX530VX Dual-Band 2GHz & 5GHz 3x3 MIMO 802.11ac wifi module
发布时间:2022-12-8 15:16
发布者:wifi6_module
qca9880
FEATURES: - Specifically designed for dual-band wireless access points - Qualcomm® Atheros QCA9880 - Maximum output power: 2.4GHz: 21dBm , 5GHz: 20dBm (per chain) - Compatible with IEEE 802.11ac and backward compatible with 802.11a/b/g/n/ac - 3x3 MIMO, rate up to 1300Mbps - Mini PCI Express connector - Supports Spatial Multiplexing, Cyclic Delay Diversity (CDD), Low-Density Parity Check (LDPC) codes, Maximum Ratio Combining (MRC), - Space Time Block Code (STBC) - Supports IEEE 802.11d, e, h, i, k, r, v timestamp and w standards - Support Dynamic Frequency Selection (DFS) - Cards are individually calibrated for the guaranteed quality SPECIFICATIONS: Chip: QCA9880 Reference Design: XB140-020 Host Connector: Mini PCI Express 1.1 standard Working voltage: 3.3V DC Antenna Connector: 3xU.FL Frequency range: optional dual-band, 2.4GHz: 2.412GHz~2.472GHz or 5GHz: 5.150GHz~5.825GHz Certifications: FCC & CE certification, REACH & RoHS compliance Maximum power consumption: 5W Supported operating systems: Qualcomm® Atheros Wireless LAN Driver or OpenWrt/LEDE with ath10k wireless driver Modulation Methods: OFDM: BPSK, QPSK, DBPSK, DQPSK, 16-QAM, 64-QAM, 256-QAM Ambient temperature: Operating temperature: -20°C~70°C / -4 ~ 158℉ Storage temperature: -40°C~90°C/ -40 ~ 130℉ Ambient humidity (non-condensing): working temperature: 5% ~ 95%, storage temperature: maximum 90% ESD Sensitivity Classification: 1C Dims (mm): 50.9 × 30.0 × 3.2 |
