QCA9882/QCA9880 802.11ac Dual band 2x2 2.4G/5G FCC/CE
Qualcomm-Atheros QCA9880 chipset 2.4GHz max 24dBm & 5GHz max 23dBm output power IEEE 802.11accompliant & backward compatible with 802.11a/b/g/n 2x2 MIMO Technology, up to 867Mbps Mini PCI Express edge connector Support the Frequency 4920MHz~4980MHz RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals Supports Spatial Multiplexing, Cyclic-Delay Diversity (CDD), Low-Density Parity Check (LDPC) Codes, Maximal Ratio Combining (MRC), Space Time Block Code (STBC) Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards Supports Dynamic Frequency Selection (DFS)
Wallys Communications (Suzhou) Co LTD develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, We're a supplier to Facebook. welcome to consult. (Web:wallystech com) EMAIL:sales@wallystech.com WEB:https://www.wallystech.com/
Symbol
| Parameter
| Chipset
| QCA9880
| Host Interface
| Mini PCI Express 1.1 Standard
| Antenna Connector
| 2 x UF.L
| Frequency Range
| 2.4GHz: 2.412GHz to 2.472GHz
5GHz: 4.920GHz to 5.825GHz
| Operating Voltage
| 3.3V DC
| Power Consumption
| 5W(Max)
| Modulation Techniques
| OFDM: BPSK, QPSK, DBPSK, DQPSK, 16-QAM, 64-QAM, 256-QAM
| Environmental Temperature
| Operating: -40°C to 70°C, Storage: -40°C to 90°C
| Environmental Humidity, non-condensing
| Operating: 5% to 95%, Storage: Max. 90%
| ROHS Compliance
| YES
| Dimensions (W×H×D)
| 30.0mm × 50.9mm × 3.2mm
Operating Mode | Data Rate | RX Sensitivity | Tolerance | 2.4 GHz 802.11b | 1Mbps | -95dBm | ±2dB | 2Mbps | -94dBm | ±2dB | 5.5Mbps | -92dBm | ±2dB | 11Mbps | -90dBm | ±2dB | 2.4 GHz 802.11g | 6Mbps | -94dBm | ±2dB | 9Mbps | -93dBm | ±2dB | 12Mbps | -92dBm | ±2dB | 18Mbps | -90dBm | ±2dB | 24Mbps | -88dBm | ±2dB | 36Mbps | -85dBm | ±2dB | 48Mbps | -81dBm | ±2dB | 54Mbps | -80dBm | ±2dB | 2.4 GHz 802.11n HT20 | MCS0 | -93dBm | ±2dB | MCS1 | -91dBm | ±2dB | MCS2 | -89dBm | ±2dB | MCS3 | -84dBm | ±2dB | MCS4 | -83dBm | ±2dB | MCS5 | -78dBm | ±2dB | MCS6 | -78dBm | ±2dB | MCS7 | -76dBm | ±2dB | 2.4 GHz 802.11n HT20 | MCS0 | -92dBm | ±2dB | MCS1 | -88dBm | ±2dB | MCS2 | -85dBm | ±2dB | MCS3 | -82dBm | ±2dB | MCS4 | -79dBm | ±2dB | MCS5 | -75dBm | ±2dB | MCS6 | -75dBm | ±2dB | MCS7 | -73dBm | ±2dB |
Operating Mode | Data Rate | TX Power | Tolerance | 1 Chain | 2 Chains | 2.4 GHz
802.11b
| 1Mbps | 20dBm | 23dBm | ±2dB | 2Mbps | 20dBm | 23dBm | ±2dB | 5.5Mbps | 20dBm | 23dBm | ±2dB | 11Mbps | 20dBm | 23dBm | ±2dB | 2.4 GHz
802.11g
| 6Mbps | 21dBm | 24dBm | ±2dB | 9Mbps | 21dBm | 24dBm | ±2dB | 12Mbps | 21dBm | 24dBm | ±2dB | 18Mbps | 21dBm | 24dBm | ±2dB | 24Mbps | 21dBm | 24dBm | ±2dB | 36Mbps | 20dBm | 23dBm | ±2dB | 48Mbps | 19dBm | 22dBm | ±2dB | 54Mbps | 19dBm | 22dBm | ±2dB | 2.4 GHz
802.11n HT20
| MCS0 | 21dBm | 24dBm | ±2dB | MCS1 | 21dBm | 24dBm | ±2dB | MCS2 | 21dBm | 24dBm | ±2dB | MCS3 | 20dBm | 23dBm | ±2dB | MCS4 | 20dBm | 23dBm | ±2dB | MCS5 | 20dBm | 23dBm | ±2dB | MCS6 | 19dBm | 22dBm | ±2dB | MCS7 | 19dBm | 22dBm | ±2dB | 2.4 GHz
802.11n HT40
| MCS0 | 21dBm | 24dBm | ±2dB | MCS1 | 21dBm | 24dBm | ±2dB | MCS2 | 21dBm | 24dBm | ±2dB | MCS3 | 20dBm | 23dBm | ±2dB | MCS4 | 20dBm | 23dBm | ±2dB | MCS5 | 20dBm | 23dBm | ±2dB | MCS6 | 19dBm | 22dBm | ±2dB | MCS7 | 18dBm | 21dBm | ±2dB |
Operating Mode | Data Rate | RX Sensitivity | Tolerance | 2.4 GHz 802.11b | 1Mbps | -95dBm | ±2dB | 2Mbps | -94dBm | ±2dB | 5.5Mbps | -92dBm | ±2dB | 11Mbps | -90dBm | ±2dB | 2.4 GHz 802.11g | 6Mbps | -94dBm | ±2dB | 9Mbps | -93dBm | ±2dB | 12Mbps | -92dBm | ±2dB | 18Mbps | -90dBm | ±2dB | 24Mbps | -88dBm | ±2dB | 36Mbps | -85dBm | ±2dB | 48Mbps | -81dBm | ±2dB | 54Mbps | -80dBm | ±2dB | 2.4 GHz 802.11n HT20 | MCS0 | -93dBm | ±2dB | MCS1 | -91dBm | ±2dB | MCS2 | -89dBm | ±2dB | MCS3 | -84dBm | ±2dB | MCS4 | -83dBm | ±2dB | MCS5 | -78dBm | ±2dB | MCS6 | -78dBm | ±2dB | MCS7 | -76dBm | ±2dB | 2.4 GHz 802.11n HT40 | MCS0 | -92dBm | ±2dB | MCS1 | -88dBm | ±2dB | MCS2 | -85dBm | ±2dB | MCS3 | -82dBm | ±2dB | MCS4 | -79dBm | ±2dB | MCS5 | -75dBm | ±2dB | MCS6 | -75dBm | ±2dB | MCS7 | -73dBm | ±2dB |
