查看: 703|回复: 0
[供应] Wifi6E-Qualcomm-QCN9074 M-2-E-Key-Interface-802-11ax-wallys
发表于 2022-4-21 11:14:17 | 显示全部楼层 |阅读模式
关键词: QCN9074 , QCA9880 , WIFI6
Wifi6E-Qualcomm-QCN9074/QCA9882 M-2-E-Key-Interface-802-11ax-wallys
■ Qualcomm Atheros QCN9074
■ 6GHz, max 23dBm per chain, up to 4949Mbps
■ Single Band 6GHz 4x4 WiFi 6E (802.11ax)
■ 4 spatial streams (4SS)
■ M.2 E Key Interface
■ PCI Express 3.0 Interface
    Absolute Maximum Rating
    Parameter
    Rating
    Unit
    Operating Temperature Range
    -20 to 70
    oC
    Storage Temperature Range
    -40 to 90
    oC
    Operating Humidity Range
    5 to +95 (non-condensing)
    Storage Humidity Range
    0 to +90 (non-condensing)
    Hardware Specifications
    Symbol
    Parameter
    Chipset
    WLAN Host Interface
    System Memory
    2Mbit serial I2C bus EEPROM
    Standard Operating Voltage
    5V
    Operating Systems
    QSDK
    Host Interface
    M.2 E Key
    Antenna Cable / Port
    4 x MMCX Connectors,4T4R
    Frequency Range
    5.925GHz-7.125GHz
    Data Rates for WALN
    Channel Spectrum Widths for WLAN
    Support 20/40/80/160MHz at 6GHz
    Modulation Techniques
    OFDMA: BPSK, QPSK, DBPSK, DQPSK,16-QAM, 64-QAM, 256-QAM,1024-QAM, 4096-QAM
    Temperature Range
    Operating: -20°C to 70°C, Storage: -40°C to 90°C
    Humidity
    Operating: 5% to 95% (non-condensing), Storage: Max. 90% (non-condensing)
    Certification
    TBD
    Power Consumption
    TBD
    Reference Design
    PN02.7
    Dimensions (WxHxD)
    57mm x 63mm x 6mm
    Wallys Communications (Suzhou) Co LTD  develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, welcome to consult.
    EMAIL:sales@wallystech.com
    WEB:https://www.wallystech.com/
