查看: 1437|回复: 0
[供应] wallys QCA9882 QCA9880 802.11AC 802.11AN wifi
发表于 2022-5-12 15:16:51 | 显示全部楼层 |阅读模式
关键词: QCA9882 , QCA9880 , 802.11AC
Featuring with industrial-grade Atheros’s QCA9882 chipset
Integrated with 2x 2 5G high power Radio Card
4.940GHz to 5.825GHz Frequency Range
2 x 5G MMCX Connectors
20MHz/40MHz/80MHz Bandwidth
Support 802. 11AC/AN
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
    Absolute Maximum Rating
    Parameter
    Rating
    Unit
    Supply Voltage
    3.3V(MINIPCIE)
    V
    Operating Temperature Range
    -40 to +60
    oC
    Storage Temperature Range
    -65 to +105
    oC
    Operating Humidity Range
    5 to +95 (non-condensing)
    Storage Humidity Range
    0 to +90 (non-condensing)
    Hardware Specifications
    Symbol
    Parameter
    CPU
    QCA9882
    Antenna Connector
    2 x 5G MMCX connectors
    ROHS Compliance
    YES
    Dimension
    50mm x 30mm x 16mm
    Radio TX Specifications
    Operating Mode
    Data Rate
    Power
    Tolerance
    1 Chain
    2 Chains
    802.11a
    6 Mbps
    25dBm
    28dbm
    ±2dB
    54 Mbps
    21dBm
    24dbm
    ±2dB
    802.11n HT20
    MCS0, MCS8
    25dBm
    28dbm
    ±2dB
    MCS7, MCS15
    20dBm
    23dbm
    ±2dB
    802.11n HT40
    MCS0, MCS8
    25dBm
    28dbm
    ±2dB
    MCS7, MCS15
    20dBm
    23dbm
    ±2dB
    802.11ac
    MCS0, MCS10,MCS20
    25dBm
    28dbm
    ±2dB
    MCS9,MCS19,MCS29
    17dBm
    20dbm
    ±2dB
    Radio RX Specifications
    Operating Mode
    Data Rate
    Sensitivity
    802.11a
    6 Mbps
    -96dBm
    54 Mbps
    -78dBm
    802.11n HT20
    MCS0, MCS8
    -92dBm
    MCS7, MCS15
    -73dBm
    802.11n HT40
    MCS0, MCS8
    -90dBm
    MCS7, MCS15
    -70dBm
    Wallys Communications (Suzhou) Co LTD  develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, We're a supplier to Facebook. welcome to consult. (Web:wallystech  com)
    EMAIL:sales@wallystech.com
    WEB:https://www.wallystech.com/
