瑞萨晶体管/晶闸管/双向晶闸管/通用IC选型手册
发布时间:2015-1-13 15:52
索引 [Index] ······· 2~10 用于PFC电源的IC [ICs for PFC Power Supply] ·······11 用于隔离型开关电源的IC [ICs for DC/DC Converter] ························13 用于系统电源的IC [System Power Management ICs] ·······················14 并联稳压器 [Shunt Regulators] ········15 三端稳压器 [3 Terminal Regulators] ·····················16,17 充电器IC [Charger ICs] ····················18 复位IC(电压检测器) [Reset ICs(Voltage Detectors) ·19 运算放大器 [Operational Amplifiers] ·················· 20~22 电压比较器 [Voltage Comparators] ··23 I/O扩展器 [I/O Expanders] ···············24 标准带包装规格 [Standard Taping Specifications] ····25 型号的命名方法 [Part No. Destination] ················26,27 封装代码 [Package Code]················28 封装 [Package] ·······29 封装和标准带包装规格 [Package and Standard Taping Specifications] ················30,31 内置电阻的晶体管 ···32 双极性晶体管 ·····33,34 用于高频放大器的小信号Bip-TRSs [Small Signal Bip-TRSs for High Frequency Amplifier] ················34 用于一般放大器的小信号TRSs [Small Signal TRSs for General Amplifier] ················34 用于高频放大器的功率MOSFET [Power MOSFETs for High Frequency Amplifier] ····35 用于高频放大器的双MOSFET [Twin-type MOSFETs for High Frequency Amplifier] ··35 用于高频放大器的小信号MOSFET [Small Signal MOSFETs for High Frequency Amplifier] ···············35 用于一般放大器的小信号MOSFET [Small Signal MOSFETs for General Amplifier] ···35 用于小信号开关的MOSFET(μFET) [Small Signal Switching use MOSFET(μFET)] ···35 结型场效应晶体管(J-FET) ················35 型号的命名方法 [Part No. Destination] ·············· 36~38 用于一般开关的功率MOSFET [Power MOSFETs for General Switching] ··········· 39~47 用于一般放大器的功率MOSFET [Power MOSFETs for General Amplifier] ················48 功率MOSFET [Power MOSFETs] 小功率MOSFET ····················48 小信号MOSFET ····················49 用于手机电池保护的功率MOSFET ················49 用于PC/电池保护的功率MOSFET [Power MOSFETs for Protection use of PC and Battery] ···50 内置热关断功能的MOSFET [Thermal Shut Down Functioned MOSFET] ·······51 驱动器IC/MOSFET集成SiP(DrMOS) [Driver IC-MOSFET Integrated SiP(DrMOS)] ·················51 用于车载的功率MOSFET [Power MOSFETs for Automobile use] ···················51 智能功率器件 ··········51 IGBT 普通用的IGBT [IGBTs for General use] ···········52 用于闪光灯的IGBT [IGBTs for Strobe use] ····52 用于PDP的IGBT [IGBTs for PDP use] ···········52 用于点火器的IGBT [IGBTs for Lgniter use] ····52 双向晶闸管 [Triacs] ·53 晶闸管 [Thyristors] ··54 晶体管阵列 ··············54 标准包装规格 [Standard Packaging Specifications] ·55 标准带包装规格 [Standard Taping Specifications] ····56 封装 [Package] ·······57 封装和标准带包装规格 [Package and Standard Taping Specifications] ·············· 58~61 贴面封装产品标记一览表 [Surface Mount Type Marking] ··················62 Renesas VP~瑞萨 功率MOSFET模拟站点 [Renesas VP~Renesas Power MOSFETs Simulation Site] ···············62 资料下载: |
