On Semi NCV8855多输出电源控制解决方案
发布时间:2012-7-30 11:14    发布者:1770309616
关键词: NCV8855 , On Semi , 电源
On Semi公司的NCV8855是集成了高边负载开关的多输出电源控制器/稳压器,能满足汽车无线系统和仪表盘电源的要求. NCV8855还集成了开关电源(SMPS)降压控制器,2.5A SMPS降压稳压器和两个低压降(LDO)线性稳压器控制器,和超低静态电流的NCV861x一起能组成8输出的无线系统或仪表盘电源解决方案.器件满足ES−XW7T−1A278−AB测试脉冲G负载条件,VIN工作电压9.0V-18.0V.本文介绍了NCV8855主要特性, 应用电路/方框图, 汽车无线电系统框图以及NCV8855评估板电路图与材料清单.
The NCV8855 is a multiple output controller / regulator IC with an integrated high−side load switch. The NCV8855 addresses automotive radio system and instrument cluster power supply requirements. In addition to the high−side load switch, the NCV8855 includes a switch−mode power supply (SMPS) buck controller, a 2.5 A SMPS buck regulator and two low dropout (LDO) linear regulator controllers. The NCV8855 in combination with the ultra−low quiescent current NCV861x IC forms an eight−output automotive radio or instrument cluster power solution. The NCV8855 has an internally set switching frequency of 170 kHz, with a SYNC pin for external frequency synchronization.
The NCV8855 is intended to supply power to various loads, such as a tuner, CD logic, audio processor and CD / tape control within a car radio. The high−side switch can be used for a CD / tape mechanism or switching an electrically−powered antenna or display unit. In an  instrument cluster application, the NCV8855 can be used to power graphics display, flash memory and CAN transceivers. In addition, the high−side switch can be used to limit power to a TFT display during a battery over−voltage condition.
NCV8855主要特性:
• < 1 uA Shutdown Current
• Meets ES−XW7T−1A278−AB Test Pulse G – Loaded Conditions
• VIN Operating Range 9.0 to 18.0 V
• 1 SMPS Controller with Adjustable Current Limit
• 1 SMPS Regulator with Internal 300 m  NMOS Switch
• 2 LDO Controllers with Current Limit and Short Circuit Protection
• 1 High−side Load Switch with Internal 300 m  NMOS FET
• Adjustable Output Voltage for All Controllers / Regulators
• 800 mV, +/-1% Reference Voltage
• System Enable Pin
• Single Enable Pin for Both LDO Controllers
• Independent Enable for High−side Load Switch
• Thermal Shutdown with Thermal Warning Indicator
• This is a Pb−Free Device
NCV8855应用:
• Automotive Radio
• Instrument Cluster, Driver Information System (DIS)
图1. NCV8855应用电路/方框图
图2. NCV8855和NCV8612汽车无线电系统框图
NCV8855评估板
图3.评估板NCV8855BMNR2GEV外形图
图4.评估板NCV8855BMNR2GEV电路图
评估板NCV8855BMNR2GEV材料清单:
详情请见:
EVBUM2120-D[1].pdf (731.53 KB)
NCV8855BMNR2GEVB_SCHEMATIC[1].pdf (294.76 KB)
来源:网络
本文地址:https://www.eechina.com/thread-94719-1-1.html     【打印本页】
