ST SPEAr310嵌入330MHz MPU开发方案
发布时间:2012-7-4 10:24    发布者:1770309616
关键词: MPU , SPEAr310 , ST
ST 公司的SPEAr310是采用ARM926EJ-S处理器(高达333MHz)的嵌入MPU,具有高性能的8路DMA,动态省功耗特性,可配置的外设功能,具有扩展的连接特性,主要用在路由器,交换和网关,遥控和计量集中器.本文介绍了SPEAr310主要特性,方框图,采用SPEAr310的系统架构图以及评估板EVALSPEAr310主要特性,方框图,电路图,材料清单和PCB布局图.
The SPEAr310 is a member of the SPEAr family of embedded MPUs, optimized for telecom applications. It is based on the powerful ARM926EJ-S processor (up to 333 MHz), widely used in applications where high computation performance is required.
In addition, SPEAr310 has an MMU that allows virtual memory management -- making the system compliant with advanced operating systems, like Linux. It also offers 16 KB of data cache, 16 KB of instruction cache, JTAG and ETM (embedded trace macro-cell) for debug operations.
A full set of peripherals allows the system to be used in many applications, some typical applications being routers, switches and gateways as well as remote apparatus control and metering concentrators.
SPEAr310主要特性:
■ ARM926EJ-S 333 MHz core
■ High-performance 8-channel DMA
■ Dynamic power-saving features
■ Configurable peripheral functions multiplexed on 102 shared I/Os
■ Memory:
– 32 KB ROM and 8 KB internal SRAM
– LPDDR-333/DDR2-666 external memory interface
– Serial Flash Memory interface (SMI)
– Flexible static memory controller (FSMC) up to 16-bit data bus width, supporting NAND Flash
– External memory interface (EMI) up to 32- bit data bus width, supporting NOR Flash and FPGAs
■ Connectivity
– 2 x USB 2.0 Host
– USB 2.0 Device
– 1 x fast Ethernet MII port
– 4 x fast Ethernet SMII ports
– 1 x SSP Synchronous serial peripheral (SPI, Microwire or TI protocol) with 4 chip selects
– 1 x I2C
– 1 x fast IrDA interface
– 6 x UART interface
– 1x TDM/E1 HDLC interface with 128/32 timeslots per frame respectively
– 2x RS485 HDLC ports
■ Security
– C3 Cryptographic accelerator
■ Miscellaneous functions
– Integrated real time clock, watchdog, and system controller
– 8-channel 10-bit ADC, 1 Msps
– JPEG CODEC accelerator
– Six 16-bit general purpose timers with programmable prescaler, 4 capture inputs – Up to 102 GPIOs with interrupt capability
SPEAr310应用:
The SPEAr310 embedded MPU is configurable for a range of telecom and networking applications such as:
■ Routers, switches and gateways
■ Remote apparatus control
■ Metering concentrators
图1.SPEAr310功能方框图
图2.采用SPEAr310的系统架构图
评估板EVALSPEAr310
EVALSPEAr310 - evaluation board for the SPEAr310
The EVALSPEAR310 board is equipped with one MII Ethernet port, four SMII Ethernet ports, six RS232 ports, two HDLC based RS485 ports and one E1/TDM port. Memory devices included are NAND Flash, parallel NOR Flash, serial NOR Flash, and I²C EEPROM.
图3.评估板EVALSPEAr310外形图
评估板EVALSPEAr310包括:
● SPEAr310 evaluation board
● AC adapter (output voltage 5 V)
● 2 plug adapters (USA/Europe)
● User manual
评估板EVALSPEAr310主要特性:
● SPEAr310 embedded MPU
● Up to 2 Gbits DDR2 333 MHz (std 128 Mbytes)
● Up to 1.5 Gbytes Parallel NOR Flash (std 16 Mbytes)
● Up to 16 Mbytes Serial NOR Flash memory (std 64 Mbytes)
● Up to 2 Gbits NAND Flash memory (std 64 Mbytes)
● 4 Kb Serial I2C EEPROM
● 4 Mb SPI Flash memory
● Two USB 2.0 full Host port channels
● One USB 2.0 high speed Device
● One 10/100 Ethernet port based on MII PHY
● Four 10/100 Ethernet port based on SMII PHY
● One E1, 2x BNC/RJ48(2.048 Mbits)
● Two HDLC RS485 DB9 ports (up to 4 MHz)
● One HDLC-TDM port (8 Mb, 128 TS)
● Six Serial ports (up to 115 kbaud)
● 8 ADC channels (10 bit, 1 Msamples)
● 6 GPIOs
● JTAG debug port
图4.评估板EVALSPEAr310方框图
评估板EVALSPEAr310材料清单:
图5.评估板EVALSPEAr310 PCB元件布局图:顶层
图6.评估板EVALSPEAr310 PCB元件布局图:底层
评估板: 评估板EVALSPEAr310电路图.pdf (451.14 KB)
详情请见:
CD00252408.pdf (920.57 KB)
CD00253463.pdf (965.53 KB)
以及
evalspear310_schematics.pdf (451.14 KB)
来源:网络
本文地址:https://www.eechina.com/thread-93538-1-1.html     【打印本页】
  • 初学者在电源电路设计中常犯的错误(以及如何避免)
