三伍微 射频开关WiFi GSR1370S 兼容替代
发布时间:2024-8-28 15:46    发布者:Penny2023
关键词: 射频前端芯片 , 射频开关 , 路由器 , 无线通信 , 物联网
三伍微 射频开关WiFi GSR1370S 兼容替代 SKY/RTC/KCT/Qorvo
GSR1370S: CMOS SOI SPDT Switch 0.01 – 7.2 GHz
Applications
*WLAN 802.11a/b/g/n/ac/ax networks
* ISM band radios
* Low power T/R systems
Features
*P0.1dB +32dBm typical @ +3.3V
*Low insertion loss (0.50dB @ 2.5GHz, 0.58dB @ 5.8GHz)
* High isolation (25dB @ 2.5GHz)
* Low delay, switch time: 75~125nS
* 1.5mm × 1.5mm QFN Package (MSL3, 260°C per JEDEC-J-STD-020)
Description
Using advanced switching technologies, the GSR1370S is a single pole dual throw (SPDT) high power switch in a low cost miniature 1.5 mm × 1.5 mm package. The GSR1370S is ideally suited for applications where high power, low insertion loss and small size are required. Typical applications are for handset systems that connect separate transmit and receive functions to a common antenna, as well as other related handset and general purpose applications. This part can be used in all systems operating up to 7.2 GHz required high power at low control voltage.
本文地址:https://www.eechina.com/thread-869478-1-1.html     【打印本页】
