Delphi:两个高效的哈希函数
发布时间:2011-3-29 20:15    发布者:1770309616
关键词: Delphi , 哈希函数
view plaincopy to clipboardprint?
01.function BKDRHash(buf: Pointer; count: Integer) : Cardinal; assembler;
02.asm
03.        PUSH  EBX;
04.        XOR   EBX, EBX
05.        MOV   ECX, EAX
06.        XOR   EAX, EAX
07.@LOOP:
08.        TEST  EDX, EDX
09.        JZ    @EXIT
10.        MOV   BL,  [ECX]
11.        IMUL  EAX, 131
12.        ADD   EAX, EBX
13.        INC   ECX
14.        DEC   EDX
15.        JMP   @LOOP
16.@EXIT:
17.        POP   EBX
18.//----------------------------
19.// Pascal:
20.//
21.//  Result := 0;
22.//  while count > 0 do
23.//  begin
24.//    Result := (Result * 131) + PByte(buf)^;
25.//    Inc(PByte(buf));
26.//    Dec(count);
27.//  end;
28.end;
29.function DJBHash(buf: Pointer; count: Integer) : Cardinal; assembler;
30.asm
31.        PUSH  EDI
32.        PUSH  EBX
33.        XOR   EBX, EBX
34.        MOV   ECX, EAX
35.        MOV   EAX, 5381
36.@LOOP:
37.        TEST  EDX, EDX
38.        JZ    @EXIT
39.        MOV   EDI, EAX
40.        SHL   EDI, 5
41.        ADD   EAX, EDI
42.        MOV   BL, [ECX]
43.        ADD   EAX, EBX
44.        INC   ECX
45.        DEC   EDX
46.        JMP   @LOOP
47.@EXIT:
48.        POP   EBX
49.        POP   EDI
50.//----------------------------
51.// Pascal:
52.//
53.//  Result := 5381;
54.//  while count > 0 do
55.//  begin
56.//    Result := ((Result shl 5) + Result) + PByte(buf)^;
57.//    Inc(PByte(buf));
58.//    Dec(count);
59.//  end;
60.end;
asm
        PUSH  EBX;
        XOR   EBX, EBX
        MOV   ECX, EAX
        XOR   EAX, EAX
@LOOP:
        TEST  EDX, EDX
        JZ    @EXIT
        MOV   BL,  [ECX]
        IMUL  EAX, 131
        ADD   EAX, EBX
        INC   ECX
        DEC   EDX
        JMP   @LOOP
@EXIT:
        POP   EBX
// Pascal:
//  Result := 0;
//  begin
//    Inc(PByte(buf));
//    Dec(count);
//  end;
end;
asm
        PUSH  EDI
        PUSH  EBX
        XOR   EBX, EBX
        MOV   ECX, EAX
        MOV   EAX, 5381
@LOOP:
        TEST  EDX, EDX
        JZ    @EXIT
        MOV   EDI, EAX
        SHL   EDI, 5
        ADD   EAX, EDI
        MOV   BL, [ECX]
        ADD   EAX, EBX
        INC   ECX
        DEC   EDX
        JMP   @LOOP
@EXIT:
        POP   EBX
        POP   EDI
// Pascal:
//  Result := 5381;
//  begin
//    Inc(PByte(buf));
//    Dec(count);
//  end;
end; 各种哈希函数算法请参考:http://www.partow.net/programming/hashfunctions/
本文地址:https://www.eechina.com/thread-60394-1-1.html     【打印本页】
eechinaeechin 发表于 2011-6-2 15:39:34
ok
eechinaeechin 发表于 2011-6-2 15:40:01
ok
eechinaeechin 发表于 2011-6-2 15:40:17
thanks
  • 我们是Microchip
