查看: 1011|回复: 0
[供应] JLINK V9全功能ARM仿真器,支持A9,A8,新品高速不掉固件特价:399包邮
发表于 2014-2-27 07:26:50 | 显示全部楼层 |阅读模式
产品链接:http://item.taobao.com/item.htm?id=36687627833
JLINK V9支持自动升级,手动降级均可以.原装原厂固件。
采用STM32芯片,不掉固件!
实物拍摄
自动升级为最新版本!
固件版本:9.0
硬件版本:9.1
主控芯片更为STM32系列芯片。
J-LinkJTAG/SWD Emulator with USB interfaceJ-Linkis a USB powered JTAG emulator supporting a large number of CPU cores.
Based on a 32-bit RISC CPU, it can communicate at high speed with the supported target CPUs. J-Link is used around the world in tens of thousand places for development and production (flash programming) purposes.
J-Link is supported by all major IDEs such as IAR EWARM, Keil MDK, Rowley CrossWorks, Atollic TrueSTUDIO, IAR EWRX, Renesas HEW, Renesas e2studio, and many others.
Including all models, more than 100,000 J-Links have been sold so far, making J-Link probably the most popular emulator for ARM cores and the de-facto standard.
Features
  • Direct download into flash memoryof most popular microcontrollers supported
  • Supported CPUs: Any ARM7/9/11, Cortex-A5/A8/A9, Cortex-M0/M1/M3/M4, Cortex-R4, RX100/RX200/RX610/RX621/RX62N/RX62T/RX630/RX631/RX63N
  • Download speed up to 1 MByte/second
  • Supportsunlimited breakpointsin flash memory!1[url=]More info...[/url]
  • Setting breakpoints inexternalflash memory of Cortex-M systems is possible with
    J-Link's[url=]Unlimited Flash Breakpoints[/url]technology only!
  • Supported by all major IDEs[url=]More info...[/url]
  • Free software updates2, 1 year of support
  • Supports concurrent access to CPU by multiple applications3
  • Crossplatform support (runs on Windows, Linux, Mac OS X)4
  • Intelligence in the emulator firmware[url=]More info...[/url]
  • Remote Server included. Allows using J-Link remotely via TCP/IP[url=]More info...[/url]
  • GDBServer included[url=]More info...[/url]
  • Production flash programming software (J-Flash) available[url=]More info...[/url]
  • Software Developer Kit (SDK) available[url=]More info...[/url]
  • Supports multiple target interfaces: JTAG, SWD
  • Supports SWV/SWO (Serial Wire Viewer / Serial wire output)
  • Wide target voltage range: 1.2V - 3.3V, 5V tolerant
  • Supports JTAG chains with multiple devices
  • Embedded Trace Buffer (ETB) support
  • Various target adapters available, including optical isolation adapter.[url=]More info...[/url]
  • RDI interface DLL available.[url=]More info...[/url]
  • Fully plug and play compatible
  • No power supply required, powered through USB
  • Support for adaptive clocking
  • All JTAG signals can be monitored, target voltage can be measured
  • Target power supply: J-Link can supply up to 300 mA to target with overload protection
    配件清单:
    1、J-LINK V9 仿真器    1 台
    2、USB线 1 条
    3、20PIN 优质连接线 1条
