在单片机解密、IC解密过程中,不同的技术手法可能产生的解密解密就不同,而解密手法的选择除了考虑解密者本身的技术经验外,还应该对需解密的单片机有一定的了解。
芯德斯长期提供各类型IC解密服务,根据IC芯片的具体特征以及客户对解密本身的具体需求选择合适的解密手法,确保解密的成功率和解密可靠性。
AT89LP216解密需求者请与我们联系。
芯德斯芯片解密服务中心欢迎您:
咨询QQ:496581979
联系电话:0755-83035820,83035862
Emai:corepcb@126.com
AT89LP214 Features:
. 8-bit Microcontroller Compatible with MCS.51 Products
. Enhanced 8051 Architecture
– Single Clock Cycle per Byte Fetch
– Up to 20 MIPS Throughput at 20 MHz Clock Frequency
– Fully Static Operation: 0 Hz to 20 MHz
– On-chip 2-cycle Hardware Multiplier
– 128 x 8 Internal RAM
– 4-level Interrupt Priority
. Nonvolatile Program Memory
– 2K Bytes of In-System Programmable (ISP) Flash Memory
– Endurance: Minimum 10,000 Write/Erase Cycles
– Serial Interface for Program Downloading
– 32-byte Fast Page Programming Mode
– 64-byte User Signature Array
– 2-level Program Memory Lock for Software Security
. Peripheral Features
– Two 16-bit Enhanced Timer/Counters
– Enhanced UART with Automatic Address Recognition and Framing Error
Detection
– Enhanced Master/Slave SPI with Double-buffered Send/Receive
– Programmable Watchdog Timer with Software Reset
– Analog Comparator with Selectable Interrupt and Debouncing
– 8 General-purpose Interrupt Pins
. Special Microcontroller Features
– Two-wire On-chip Debug Interface
– Brown-out Detection and Power-on Reset with Power-off Flag
– Internal 8 MHz RC Oscillator
– Low Power Idle and Power-down Modes
– Interrupt Recovery from Power-down Mode
. I/O and Packages
– Up to 12 Programmable I/O Lines
– Configurable I/O with Quasi-bidirectional, Input, Push-pull Output, and
Open-drain Modes
– 5V Tolerant I/O
– 14-lead TSSOP or PDIP
. Operating Conditions
– 2.4V to 5.5V VCC Voltage Range
– -40°C to 85°C Temperature Range
