ST MP34DT01和STM32数字MEMS麦克风解决方案
发布时间:2012-6-14 14:38
发布者:1770309616
ST 公司的MP34DT01是超小型低功耗全方位数字MEMS麦克风,具有容性传感元件和IC接口,单电源工作,声学过载点120 dBSPL,信噪比63dB,全方位灵敏度,灵敏度-26dBFC,PDM输出,主要用在手机,笔记本电脑,手持媒体播放器(PMP),VoIP,语音识别,数码相机和摄像机,防盗系统等.本文介绍了MP34DT01主要特性,以及采用MP34DT01和STM32 MCU的STEVAL-MKI117V1演示板主要特性,电路图,材料清单和PCB布局图. The MP34DT01 is an ultra-compact, low-power,omnidirectional, digital MEMS microphone built with a capacitive sensing element and an IC interface. The sensing element, capable of detecting acoustic waves, is manufactured using a specialized silicon micromachining process dedicated to produce audio sensors. The IC interface is manufactured using a CMOS process that allows designing a dedicated circuit able to provide a digital signal externally in PDM format. The MP34DT01 has an acoustic overload point of 120 dBSPL with a 63 dB signal-to-noise ratio and –26 dBFS sensitivity. The MP34DT01 is available in a top-port, SMDcompliant, EMI-shielded package and is guaranteed to operate over an extended temperature range from -30℃ to +70℃. MP34DT01主要特性: ■ Single supply voltage ■ Low power consumption ■ 120 dBSPL acoustic overload point ■ 63 dB signal-to-noise ratio ■ Omnidirectional sensitivity ■ –26 dBFS sensitivity ■ PDM output ■ HCLGA package – Top-port design SMD-compliant – EMI-shielded – ECOPACK® , RoHS, and “Green” compliant MP34DT01应用: ■ Mobile terminals ■ Laptop and notebook computers ■ Portable media players ■ VoIP ■ Speech recognition ■ A/V eLearning devices ■ Gaming and virtual reality input devices ■ Digital still and video cameras ■ Antitheft systems MEMS microphone demonstration board based on the MP34DT01 and STM32 The purpose of the STEVAL-MKI117V1 demonstration board is to provide an example of the decoding and streaming of digital MEMS microphone outputs. The STEVAL-MKI117V1 demonstration board hosts the MP34DT01 (bottom-port digital microphone), working as a sensor, and the STM32F107RC microcontroller, working as an audio decoder. These microphones are analog-to-digital transducers. They are able to sense sound pressure and convert this signal into a digital signal using the PDM technique. The STM32 microcontroller decodes the PDM signal coming from the microphones and streams the audio via the USB. The STEVAL-MKI117V1 demonstration board is a sound card automatically recognized by the PC as an audio device. Connection is made through a USB cable which also supplies the board and then streams the collected audio. STEVAL-MKI117V1演示板主要特性: ■ Powered and connected to PC through USB ■ Sound card automatically recognized by the PC as an audio device ■ The onboard microphones are digital MEMS devices ■ MEMS microphones provide a high frequency data stream (1 to 3.25 MHz) of 1-bit digital samples (PDM technique) ■ Audio collected from the microphones is sent to the PC through the USB ■ LED status indicator ■ RoHS compliant 图1.STEVAL-MKI117V1演示板外形图:左,顶视图,右,底视图 图2.STEVAL-MKI117V1演示板电路图(1) 图3.STEVAL-MKI117V1演示板电路图(2) STEVAL-MKI117V1演示板材料清单: 图4.STEVAL-MKI117V1演示板PCB布局图:顶层 图5.STEVAL-MKI117V1演示板PCB布局图:底层 详情请见: 来源:网络 |
