查看: 409|回复: 0
[供应] ZC2205-24V 500mA Ultralow-Quiescent-Current LDO
发表于 2023-11-20 15:59:24 | 显示全部楼层 |阅读模式
关键词: ZC2205-24V , 500mA , LDO
ZC2205-24V500mAUltralow-Quiescent-Current LDO
General Description
The ZC2205 ultra-low quiescent current regulator features low dropout voltage and low current in the standby mode. With less than 1.5μA quiescent current at no load, the ZC 2205 is ide ally suited for standby micro-control-unit systems, especially for always-on applications like E-meters, fire alarms, smoke detectors and other battery operated systems. The ZC2205 retains all o f the features that are common to low dropout regulators including a low dropout PMOS pass devi ce, short circuit protection, and thermal shutdown.
The ZC2205 has a 24-V maximum operating voltage limit, a -40°C to 125°C operating temperat ure range, and ±2% output voltage Tolerance
Features
⚫ VIN Range up to 24V
⚫ Output Voltage Tolerances of ±2%
⚫ Output Current of 500 mA
⚫ Ultra Low Quiescent Current (IQ = 1.5 μA)
⚫ Internal Thermal Overload Protection500 mA
⚫ Internal Short-Circuit Current Limit Dropout Voltage Typically 24V atIOUT =500 mA
⚫    Ceramic Capacitor Stable
Application
⚫ E-meters, Water Meters and Gas Meters
⚫ Fire Alarm, Smoke Detector
⚫ Appliances and White Goods
