DR882 Wallys Communications (Suzhou ) Co., LTD( http://www.wallystech.com) is a professional supplier of wireless communication products and has a complete industrial chain in China. Our biggest advantage is our independent research and development ability, which can support you in the later period. IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/ipq4018/IPQ8072/IPQ8074/QCN9074/QCN9072/QCN9024/IPQ5018/AR9223/QCA9880/QCA9882 /AR9582/AR9531/AR9344/AR9531 BY:Wallys Communications (Suzhou ) Co., LTD
wifi6 router/network card wifi 6E WiFi 6 802.11ax/802.11ac wireless solutions Dipole/ panel //Dual Polarization Enclosure /Smart /omni /Antenna Wireless Access Point/Point to Point / Featuring with industrial-grade Atheros’s QCA9882 chipset Integrated with 2x 2 5G high power Radio Card 4.940GHz to 5.825GHz Frequency Range 2 x 5G MMCX Connectors 20MHz/40MHz/80MHz Bandwidth Support 802. 11AC/AN RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals DR882 is an industrial grade Atheros QCA9882 chipset, which is integrated with two 2.5G high power Radio Card. The frequency range covers the 4.940GHz to 5.825GHz band. It supports 802.11AC/AN and has a 20MHz/40MHz/80MHz bandwidth. It is RoHS compliant, ensuring a high level protection of human health and the environment from risks that can be posed by chemicals.
Parameter | Rating | Unit | Supply Voltage | 3.3V(MINIPCIE) | V | Operating Temperature Range | -40 to +60 | oC | Storage Temperature Range | -65 to +105 | oC | Operating Humidity Range | 5 to +95 (non-condensing) | % | Storage Humidity Range | 0 to +90 (non-condensing) | % |
Symbol | Parameter | CPU | QCA9882 | Antenna Connector | 2 x 5G MMCX connectors | ROHS Compliance | YES | Dimension | 50mm x 30mm x 16mm |
Operating Mode | Data Rate | Power | Tolerance | 1 Chain | 2 Chains | 802.11a | 6 Mbps | 25dBm | 28dbm | ±2dB | 54 Mbps | 21dBm | 24dbm | ±2dB | 802.11n HT20 | MCS0, MCS8 | 25dBm | 28dbm | ±2dB | MCS7, MCS15 | 20dBm | 23dbm | ±2dB | 802.11n HT40 | MCS0, MCS8 | 25dBm | 28dbm | ±2dB | MCS7, MCS15 | 20dBm | 23dbm | ±2dB | 802.11ac | MCS0, MCS10,MCS20 | 25dBm | 28dbm | ±2dB | MCS9,MCS19,MCS29 | 17dBm | 20dbm | ±2dB |
