为不同版本的Expedition,PADS指定不同的WIDIR
发布时间:2013-7-17 22:35    发布者:fenghaili
关键词: Mentor , PADS , WDIR
发帖人 andrew_audova 开启 2013-7-14 0:06:21
Some of the files under the WDIR (for example: user.cns) are not compatible with all versions of SDD (EE/BSXE/PADS/IND) Flow software, and in some cases can actually cause applications to crash. For this reason it is advisable to maintain a different WDIR location for each release. Here is a simple technique for doing so:
Create a Configurator.ini file. Place this file in a folder of your choice, although C:\MentorGraphics\win32 is a good and simple to find location (same directory as the Configurator.exe).
See below format, which will create a C:\WDIR\ for each release that you configure to. For example, C:\WDIR\7.9.5EE and C:\WDIR\9.5PADS, for EE7.9.5 and PADS9.5, respectively.
All three lines must appear in order for the WDIR to get set correctly. Change the MGLS_LICENSE_FILE to the port@host (or local file path) for your licensing environment.
[defaults]
MGLS_LICENSE_FILE=1717@myServer
WDIR=c:\WDIR\%SDD_VERSION%;%SDD_HOME%\standard
Create a CFGR_INI environment variable and set it to the full location of the Configurator.ini file.
For example: CFGR_INI = C:\MentorGraphics\win32\Configurator.ini
How to set or edit an environment variable on Windows
With this setup in place, every time you run the Configurator to switch versions the WDIR will change to the appropriate release-specific folder.
For more details and other WDIR switching techniques, refer to pages 98-104 of the attached Managing Mentor Graphics Systems Software (EE7.9.5) manual.
本文地址:https://www.eechina.com/thread-117429-1-1.html     【打印本页】
  • 我们是Microchip
