555555">深圳专业提供各种专业的解密服务,包括各种芯片解密、IC解密、单片机破解等,现在我公司对MFRC500芯片的解密技术的掌握已相当到位,能为您提供最有效、最科学、最专业的解密方案与服务。
下面是MFRC500芯片的解密特性与运用介绍
Features
· Highly integrated analog circuitry to decode card response
· Buffered output drivers to connect an antenna with minimum number of external components
· Proximity operating distance (up to 100 mm)
· Fast internal oscillator buffer to connect 13.56MHz quartz
· Clock frequency monitoring
· Hard reset with low power functions
· Power down mode per software
· Parallel μController interface with internal address latch and IRQ line
· Automatic detection of parallel μC interface type
· Comfortable send and receive FIFO buffer
· Anti-collision procedure support
· Bit- and byte-oriented framing
· Unique serial number
· Onboard timer circuit
· Supports MIFARE® PRO and ISO 14443A(transparent mode and T=”CL” )
· Supports MIFARE® Classic
· Crypto1 and secure non-volatile internal key memory
· Supports MIFARE® active antenna concept.
· Suitable for high security terminals with SAM’sbased on e.g. triple DES, RSA, elliptic curves
Applications
The MF RC500 is tailored to fit the requirements of various applications using contactless communication based on ISO/IEC 14443A standard where cost-effectiveness, small size,high performance with a single voltage supply areimportant.
· Public transport terminals
· Handheld terminals
· On board units
· Contactless PC terminals
· Metering
· Contactless public phones
欢迎访问咨询深圳了解更多更详细的解密服务。
本资料由www.atmegajiemi.org整理提供。
