Atmel RZRAVEN低功耗2.4GHz ZigBee应用方案
发布时间:2012-8-18 10:16    发布者:1770309616
关键词: Atmel , RZRAVEN , ZigBee
Atmel公司的RZRAVEN是AT86RF230 2.4GHz无线收发器AVR微控制器的开发套件,是开发和调试各种RF应用的专业平台,通过LCD和音频输入和输出提供良好大案人工接口,适合于IEEE 802.15.4™, ZigBee®, 6LoWPAN, RF4CE, SP100, WirelessHART™ 和 ISM应用以及无线传感器网络,消费类电子,工业控制和PC外设.本文介绍了AT86RF230主要特性,框图,应用电路图以及开发套件RZRAVEN主要特性,AVRRAVEN框图,电路图和材料清单,PCB元件布局图与RZUSBSTICK框图,电路图和材料清单,PCB元件布局图.
The AT86RF230 is a low-power 2.4 GHz radio transceiver especially designed for ZigBee/IEEE 802.15.4 applications. The AT86RF230 is a true SPI-to-antenna solution. All RF-critical components except the antenna, crystal and de-coupling capacitors are integrated on-chip. Therefore, the AT86RF230 is particularly suitable for applications like:
• 2.4 GHz IEEE 802.15.4 and ZigBee systems
• 6LoWPAN and RF4CE systems
• Wireless sensor networks
• Industrial control, sensing and automation (SP100, WirelessHART)
• Home and building automation
• Consumer electronics
• PC peripherals
The AT86RF230 can be operated by using an external microcontroller like ATMEL’s AVR microcontrollers. A comprehensive software programming description can be found in the application note AVR2009 “AT86RF230 – Software Programming Model”.
This single-chip radio transceiver provides a complete radio transceiver interface between the antenna and the microcontroller. It comprises the analog radio transceiver and the digital demodulation including time and frequency synchronization, and data buffering. The number of external components is minimized such that only an antenna, a crystal and four decoupling capacitors are required. The bidirectional differential antenna pins are used for transmission and reception, so that no external antenna switch is needed.
The received RF signal at pins RFN and RFP is differentially fed through the low-noise amplifier (LNA) to the RF filter (PPF) to generate a complex signal. This signal is converted down by mixers to an intermediate frequency and fed to the integrated channel filter (SSBF). The limiting amplifier provides sufficient gain to drive the succeeding analog-to-digital converter (ADC) and generates a digital RSSI signal with 3 dB granularity. The ADC output signal is sampled by the digital base band receiver (RX BBP).
The transmit modulation scheme is offset-QPSK (O-QPSK) with half-sine pulse shaping and 32-length block coding (spreading) according to [1]. The modulation signal is generated in the digital transmitter (TX BBP) and applied to the fractional-N frequency synthesis (PLL) generating a coherent phase modulation required for demodulation of O-QPSK signals. The frequency-modulated RF signal is fed to the power amplifier (PA).An internal 128 byte RAM for RX and TX (Frame Buffer) buffers the data to be transmitted or the received data. Two on chip low dropout (LDO) voltage regulators provide the internal analog and digital 1.8V supply.
AT86RF230主要特性:
• High Performance RF-CMOS 2.4 GHz Radio Transceiver Targeted for IEEE 802.15.4™, ZigBee®, 6LoWPAN, RF4CE, SP100, WirelessHART™ and ISM Applications
• Industry Leading Link Budget (104 dB):
- Programmable Output Power from -17 dBm up to 3 dBm
- Receiver Sensitivity -101 dBm
• Ultra-Low Power Consumption:
- SLEEP: 20 nA
- RX: 15.5 mA
- TX: 16.5 mA (at max Transmit Power of 3 dBm)
• Ultra-Low Supply Voltage (1.8V to 3.6V) with Internal Regulator
• Optimized for Low BoM Cost and Ease of Production:
- Few External Components Necessary (Crystal, Capacitors and Antenna)
• Excellent ESD Robustness
• Easy to Use Interface:
- Registers and Frame Buffer Accessible through Fast SPI
- Only Two Microcontroller GPIO Lines Necessary
- One Interrupt Pin from Radio Transceiver
- Clock Output with Prescaler from Radio Transceiver
• Radio Transceiver Features:
- 128-byte SRAM for Data Buffering
- Programmable Clock Output to Clock the Host Microcontroller or as Timer Reference
- Integrated TX/RX Switch
- Fully Integrated PLL with on-chip Loop Filter
- Fast PLL Settling Time
- Battery Monitor
- Fast Power-Up Time < 1 ms
• Special IEEE 802.15.4-2003 Hardware Support:
- FCS Computation
- Clear Channel Assessment
- Energy Detection / RSSI Computation
- Automatic CSMA-CA
- Automatic Frame Retransmission
- Automatic Frame Acknowledgement
- Automatic Address Filtering
• Industrial Temperature Range:
- -40° C to 85° C
• I/O and Packages:
- 32-pin Low-Profile QFN
- RoHS/Fully Green
• Compliant to EN 300 328/440, FCC-CFR-47 Part 15, ARIB STD-66, RSS-210
• Compliant to IEEE 802.15.4-2003
图1.AT86RF230方框图
图2.AT86RF230应用电路图
AT86RF230开发套件RZRAVEN
The Atmel RZRAVEN is a development kit for the AT86RF230 radio transceiver and the AVR microcontroller. It serves as a versatile and professional platform for developing and debugging a wide range of RF applications; spanning from: simple point-to-point communication through full blown sensor networks with numerous nodes running complex communication stacks. On top of this, the kit provides a nice human interface, which spans from PC connectivity, through LCD and audio input and output.
开发套件RZRAVEN主要特性:
• Development kit for the Atmel® AT86RF230 radio transceiver and Atmel AVR®
Microcontroller
• CE, ETSI and FCC approved
• LCD module (Atmel AVRRAVEN):
• AT86RF230 radio transceiver with high gain PCB antenna
• Dual AVR microcontrollers
• Dynamic speaker and microphone
• Atmel Serial Dataflash®
• User I/O section:
• USART
• GPIO
• Relay Driver
• Powered by battery or external supply:
• 5V to 12V external supply
• USB module (Atmel RZUSBSTICK):
• AT86RF230 radio transceiver with miniature PCB antenna
• AVR microcontroller with integrated Full Speed USB interface
• External memory interface
图3.开发套件RZRAVEN外形图
图4.AVRRAVEN框图
图5.AVRRAVEN元件布局图(顶层)
图6.AVRRAVEN元件布局图(底层)
图7.Atmel AVRRAVEN电路图(1)
图8.Atmel AVRRAVEN电路图(2)
图9.Atmel AVRRAVEN电路图(3)
图10.Atmel AVRRAVEN电路图(4)
图11.Atmel AVRRAVEN电路图(5)
Atmel AVRRAVEN材料清单:
图12.RZUSBSTICK框图
图13. Atmel RZUSBSTICK电路图
Atmel RZUSBSTICK 材料清单:
图14.Atmel RZUSBSTICK元件布局图(顶层)
图15.Atmel RZUSBSTICK元件布局图(底层)
详情请见:
doc5131.pdf (1.17 MB)
doc8117.pdf (767.73 KB)
来源:网络
本文地址:https://www.eechina.com/thread-95926-1-1.html     【打印本页】
