Renesas RX63N 32位RX MCU开发方案
发布时间:2012-7-16 12:04
发布者:1770309616
Renesas公司的RX63N是100MHz 32位RX MCU ,165DMIPS性能,集成了多达2MB闪存,以太网MAC,全速USB 2.0主/功能/OTG接口,包括CAN的各种通信接口,10位和12位ADC和RTC.和现有产品相比,待机功耗降低大约90%,工作电压2.7- 3.6V,主要用在音频设备,马达控制,游戏机和通信设备.本文介绍了RX63N主要特性,方框图,RX63N开发套件应用和特性,方框图,电路图和材料清单. The RX63N/RX631 Group incorporates communication functions suitable for networking equipment, such as Ethernet controller, USB 2.0 full-speed (function, host, or OTG selectable), and CAN. In addition, with a RTC (Real-Time Clock) that can operate on a dedicated power supply as a low power feature, standby power consumption can be reduced by approximately 90% compared to existing products. The selection of on-chip memory has been expanded from ROMless to 2 MB, and even smaller-sized packages are available. This makes possible mounting in anything from large-scale systems to small-scale/small-space devices. RX63N主要特性: 32-bit RX CPU core Max. operating frequency: 100 MHz Capable of 165 DMIPS in operation at 100 MHz Single precision 32-bit IEEE-754 floating point Two types of multiply-and-accumulation unit (between memories and between registers) 32-bit multiplier (fastest instruction execution takes one CPU clock cycle) Divider (fastest instruction execution takes two CPU clock cycles) Fast interrupt CISC Harvard architecture with 5-stage pipeline Variable-length instructions: Ultra-compact code Supports the memory protection unit (MPU) JTAG and FINE (two-line) debugging interfaces Low-power design and architecture Operation from a single 2.7- to 3.6-V supply Low power consumption: A product that supports all peripheral functions draws only 500uA/MHz. RTC is capable of operation from a dedicated power supply (min. Operating voltage: 2 V). Four low-power modes On-chip main flash memory, no wait states Supports ROM-less versions and versions with up to 2 Mbytes of ROM (ROM-less version: RX631 Group only) 100-MHz operation, 10-ns read cycle (no wait states) 384-Kbyte to 2-Mbyte capacities User code programmable via the USB, SCI, or JTAG On-chip data flash memory ROM-less or 32 Kbytes of ROM (reprogrammable up to 100,000 times) Programming/erasing as background operations (BGOs) On-chip SRAM, no wait states 32- to 128-Kbyte capacities For instructions and operands Can provide backup on deep software standby DMA DMAC: Four channels DTC EXDMAC: Two channels Dedicated DMAC for the Ethernet controller: Single channel Reset and supply management Power-on reset (POR) Low voltage detection (LVD) with voltage settings Clock functions External crystal oscillator or internal PLL for operation at 4 to 16 MHz Internal 125-kHz LOCO and 50-MHz HOCO Dedicated 125-kHz LOCO for the IWDT Real-time clock Adjustment functions (30 seconds, leap year, and error) Time capture function (for capturing times in response to event-signal input on external pins) Independent watchdog timer 125-kHz LOCO clock operation Useful functions for IEC60730 compliance Oscillation-stoppage detection, frequency measurement, CRC, IWDT, selfdiagnostic function for the A/D converter, etc. Various communications interfaces Ethernet MAC (1) (not in RX631 Group products) Host/function or OTG controller (1) and function controller (1) with fullspeed USB 2.0 transfer CAN (compliant with ISO11898-1), incorporating 32 mailboxes (up to 3 modules) SCI with multiple functionalities (up to 13) Choose from among asynchronous mode, clock-synchronous mode, smartcard interface mode, simplified SPI, simplified I2C, and extended serial mode. I2C bus interface for transfer at up to 1 Mbps (up to 4) RSPI for high-speed transfer (up to 3) External address space Buses for high-speed data transfer (max. operating frequency of 50 MHz) 8 CS areas (8 ⊙ 16 Mbytes) Multiplexed address data or separate address lines are selectable per area. 8-, 16-, or 32-bit bus space is selectable per area Independent SDRAM area (128 Mbytes) Up to 20 extended-function timers 16-bit MTU2: input capture, output compare, PWM waveform output, phase-counting mode (6 channels) 16-bit TPU: input capture, output compare, phase-counting mode (12 channels) 8-bit TMR (4 channels) 16-bit compare-match timers (4 channels) A/D converter for 1-MHz Operation Up to 21 12-bit channels, and incorporating 1 sample-and-hold circuit Up to 8 10-bit channels, and incorporating 1 sample-and-hold circuit Addition of results of A/D conversion (in the 12-bit converter) Self diagnosis (for the 10-bit converter) 10-bit D/A converter: 2 channels Temperature sensor for measuring temperature within the chip Register write protection can protect values in important registers against overwriting. Up to 134 pins for GPIO 5-V tolerance, open drain, input pull-up, switchable driving ability Operating temp. range -40 degree C to +85 degree C
图1。RX63N方框图 RX63N开发套件 Renesas Demonstration Kit (RDK) for RX63N This RDK is an evaluation and demonstration tool for Renesas RX63N microcontrollers. The goal is to provide the user with a powerful debug and demonstration platform targeted at common applications. A set of human/machine interfaces are tightly integrated with the features of the RX63N and the software demonstration programs providing the user with an accessible platform to rapidly evaluate and customize. RX63N开发套件应用和特性: • Audioo Stereo audio driver connected to the PWM interface On-board microphone to demonstrate sampling, FFT/FPU capabilities Volume Control Potentiometer Micro SD card interface for audio and data files • Motor Control 3 –Phase motor control algorithm representation with LEDs Motor control algorithm speed variation through volume control potentiometer • Gaming 3 –Axis Accelerometer (Digital) User pushbutton switches • Communications 10/100 Ethernet Interface connected to an internal Ethernet MAC (1588 compatible) USB Interface connected to an internal USB controller (Host, Device and OTG) RS-232 Interface CAN Interface I2C, SPI with Debug through the Beagle connector from Total Phase PMOD connections to support a variety of generic PMOD devices (WiFi, Bluetooth, RF, and much more). • User Code and Application Debugging On-board J-Link OB for high-quality source code debugging
图2。RX63N开发套件外形图
图3。RX63N开发套件方框图
图4。RX63N开发板电路图(1)
图5。RX63N开发板电路图(2)
图6。RX63N开发板电路图(3)
图7。RX63N开发板电路图(4)
图8。RX63N开发板电路图(5)
图9。RX63N开发板电路图(6)
图10。RX63N开发板电路图(7)
图11。RX63N开发板电路图(8) RX63N开发板材料清单见:
RX63N开发板材料清单.zip
(24.69 KB)
详情请见:
r01ds0098ej0100_63n631.pdf
(1.29 MB)
和
YRDKRX63N_user_manual_10.pdf
(4.23 MB)
以及
Schematics_YRDKRX63N_SCH_3.pdf
(143.26 KB)
来源:网络 |
