Powerint LNK460VG 100W A19 LED灯电源方案
发布时间:2012-3-30 12:29    发布者:1770309616
关键词: LED , LNK460VG , Powerint , 电源
Powerint公司的DER322参考设计采用LinkSwitch-PL系列LNK460VG器件,是业界首个可替代100W A19白炽灯的LED驱动器,采用单层PCB,具有低成本少元件数和小尺寸特点,230VAC时的效率大于93%,PF大于0.9,230 VAC; 78 V LED时的THD小于20%,集成了包保护和可靠性特性,热关断自动恢复。本文介绍了LinkSwitch-PL系列产品亮点,方框图,典型应用电路以及DER322参考设计主要特性和指标,电路图,材料清单和PCB布局图。
The LinkSwitch-PL family enables a very small and low cost single-stage power factor corrected constant current driver for solid state lighting. Optimized for direct LED current sensing, the LinkSwitch-PL operates over a wide input voltage range delivering an output power of up to 16 W. The LinkSwitch-PL control algorithm provides flicker-free TRIAC dimming with minimal external components.
Each device incorporates a 725 V rated power MOSFET, a novel discontinuous mode variable frequency variable on-time controller, frequency jitter, cycle by cycle current limit and hysteretic thermal shutdown in a monolithic 4-pin IC, available in SO-8C, eSOP-12, and eDIP-12 packages.
LinkSwitch-PL系列产品亮点:
Dramatically Simplifies Off-line LED Drivers
• Flicker-free phase-controlled TRIAC dimming
• Single stage power factor correction and accurate constant current (CC) output
• Very low component count with small non-electrolytic bulk capacitor for compact replacement lamp designs
• Compact SO8, eSOP, and eDIP packages
• Completely eliminates control loop compensation
Advanced Performance Features
• Optimized for non-isolated flyback designs
• Frequency jitter greatly reduces EMI filter size and costs
• Low dissipation direct sensing of LED current
Advanced Protection and Safety Features
• Cycle skipping regulation for abnormally low output power to clamp peak output current delivered
• 725 V integrated power MOSFET allows small bulk capacitance and maximizes power capability
• Short-circuit, overload, open feedback and output overvoltage protection
• Hysteretic thermal shutdown
• Meets high-voltage creepage between DRAIN and all other pins both on PCB and at package
EcoSmart™ - Energy Efficient
• High power factor optimizes system lumen per input VA
• Control algorithm balances switching and conduction losses over line and load to maintain optimum efficiency
图1。LinkSwitch-PL系列功能方框图
图2。LinkSwitch-PL系列典型应用电路图
图3。采用LinkSwitch-PL系列的替代A19白炽灯的5W 15V LED驱动器电路图
DER322参考设计
High Efficiency (>93%), High Power Factor(>0.9), 18 W Output Non-Isolated Buck LED Driver Using LinkSwitchTM-PL LNK460VG
The document describes a non-isolated, high efficiency, high power factor (PF) LED driver designed to drive a nominal LED string voltage of 78 V at 230 mA from an input voltage range of 195 VAC to 265 VAC (47 Hz – 63 Hz). The LED driver utilizes the LNK460VG from the LinkSwitch-PL family of ICs.
The topology used is a single-stage non-isolated buck that meets the stringent space and efficiency requirements for this design. LinkSwitch-PL based designs provide high power factor (>0.9) meeting international requirements.
This document contains the LED driver specification, schematic, PCB details, bill of materials, transformer documentation and typical performance characteristics.
DER322参考设计主要特性:
 Single-stage power factor correction combined with constant current (CC) output
 Low cost, low component count, small size and single-sided PCB
 Highly energy efficient, >93% at 230 VAC input for 78 V LED Load
 Integrated protection and reliability features
 Single shot no-load protection / output short-circuit protected with auto-recovery
 Auto-recovering thermal shutdown with large hysteresis protects both components and PCB
 No damage during brown-out conditions
 PF >0.9 at 230 VAC
 % ATHD <20% at 230 VAC; 78 V LED
 Meets IEC ring wave, differential line surge and EN55015 conducted EMI
图4。DER322参考设计外形图:上:顶视图,下:底视图
DER322参考设计电源指标:
图5。DER322参考设计电路图
DER322参考设计材料清单(BOM):
图6。DER322参考设计PCB布局图(53.5 mm x 19.6 mm):上:顶层;下:底层
详情请见:
linkswitch-pl_family_datasheet[1].pdf (1.75 MB)
der322[1].pdf (4.33 MB)
来源:网络
本文地址:https://www.eechina.com/thread-88204-1-1.html     【打印本页】
