查看: 785|回复: 0
[供应] FMC377_双AD9361 射频收发模块
发表于 2023-3-5 17:13:14 | 显示全部楼层 |阅读模式
关键词: FMC377_双AD9361 , 射频收发模块
FEATURES
Coverage from 70M ~ 6GHz RF
Flexible rate 12 bit ADC/DAC
Fully-coherent 4x4 MIMO capability, TDD/FDD
RF ports: 50Ω Matched
support both internal reference and external reference input
56 MHz real-time bandwidth
Includes DC power supply
Dimensions: Standard FMC daughter Board
APPLICATIONS
SDR
Cellular, e.g.: Femto-cells, Pico-cells, Small-cells, Micro-cell & etc.
WiFi
WiMAX
ISM
Proprietary & General Purpose Radios
GENERAL DESCRIPTIONS
The FMC377 is an easy-to-use RF module covering 70MHz ~ 6GHz with integrated RFIC technology and FMC interface. The RF module features four receive and four transmit channels by using two Analog Devices RFIC, AD9361 to deliver a cost-effective experimentation platform with up to 56MHz (for 4x4) of instantaneous bandwidth, higher sensitivity, dynamic range, and IP3 performance, which is suitable for wide range of applications including SDR, cellular, WiFi, ISM, proprietary or general purpose radios and so on. With the FMC377, designers can prototype with the AD9361 quickly and easily.
CHARACTERISTICS
No.
Items
Specifications
Remark
Tx
1
Frequency
70~6000MHz
2
Bandwidth
56MHz 4x4
real-time bandwidth, tunable
3
Transmission
>10dBm
CW
4
EVM
<1.5%
Typical:5dBm @20MHz bandwidth
5
Gain Control Range
>80dB
6
Gain Step
0.25 dB
7
ACLR
< -45dBc
@ 0dBm LTE output
8
Spurious
TBD
9
SSB Suppression
35dBc
10
LO Suppression
50dBc
11
DAC Sample Rate (max)
245.76 MS/s
12
DAC Resolution
12bits
Rx
1
Frequency
70~6000MHz
2
Bandwidth
56MHz 2x2
3
Sensitivity:
-100dBm@5MHz
Noise Figure < 5dB
5
Gain Control Range
>60dB
6
Gain Step
1dB
7
Noise Figure
<5dB
Maximum RX gain
8
ADC Sample Rate (max)
122.88MS/s
9
ADC Resolution
12bits
10
ADC Wideband SFDR
78dBc
1
Voltage
3.3V & 5V
2
ON/OFF TIME
<6uS
For TDD model
3
Duplexing Model
TDD/FDD
FMC INTERFACE DEFINITION
FMC INTERFACE DEFINITION(Continued)
FMC INTERFACE DEFINITION(Continued):
Truth Table:
◆ Tx-Rx switch
Function
TRX_SW
Transmitting
1
Receiving
0
OUTLINE DIMENSIONS:
TEL:15216739004陈(微信同号)     邮箱rihard@foxmail.com
