查看: 599|回复: 0
[供应] 32位MCU,A726Q116401 一个RISCV架构单片机
发表于 2022-4-13 16:45:51 | 显示全部楼层 |阅读模式
32位MCU,A726Q116401是一个RISCV架构单片机
Introduction
A726Q116401 is a RISCV MCU. The temperature range is of -25~85. The operating frequency is 96MHz. Chip package isQFN84.
Features
-32-bit load/store reduced instruction set computer(RISCbit load/store reduced instruction set computer (RISCV) architecture withfixed 16-bit instruction length。
-16 entry 32-bit general-purpose register file
-Support for byte/halfword/word memory accesses
-Embedded interrupt controller, support nested vectorinterrupts.
• Cache
-Has two AHB bus interfaces, a master and a slaveinterface.
-Has a 2-way set-associative organization.
-Uses both the positive and negative edges of itssingle clock input
-Has an AHB bus interface to access its programmer'smodel.
Memory
•192K Bytes of static random-access memory (SRAM):
-Single cycle byte, half-word (16-bit), and word (32-bit)reads and writes
•1024K Bytes embedded flash (EFLASH)
-4KBytes page size
-Read Access Time:
50ns(max) @ EV=PV=0
200ns(max)@EV=1 or PV=1
-Endurance : 100000 Cycles(Min)
-Greater than 10 years under room temperature
-Fast Page Erase/Word Program
-Program Time of each pulse : 4.4us(Max)
-Program hold time:20ns(min)
-Mass Erase Time : 40ms(Max)
-Single cycle byte, half-word(16-bits) and word(32-bits)read access
