ADI AD8436高精度RMS到DC转换解决方案
发布时间:2011-8-18 14:37    发布者:Liming
关键词: AD8436 , ADI , DC , RMS
ADI公司的AD8436是新一代跨导线性的高精度低功耗真正的RMS/DC转换器,它能精确计算交流波形的rms值,包括由开关电源和TRIAC所产品的复数项。精度优于0.5%,输出失调小于10uV,波峰因素(CF=1-10)时的误差小于0.5%,输入范围满刻度为100 μV rms 到3 V rms (8.5 V p-p),双电源电压为 ±2.4 V到±18 V ,单电源电压为4.8 V 到36 V,主要用在遥控,手持仪表,板空间受限和户外环境的电源和汽车。本文介绍了AD8436主要特性,功能方框图,RMS核方框图,波峰因素测试电路图,典型应用电路以及AD8436-EVALZ评估板电路图和PCB布局图。
The AD8436 is a new generation, translinear precision, low power, true rms-to-dc converter that is loaded with options. It computes a precise dc equivalent of the rms value of ac waveforms, including complex patterns such as those generated by switchmode power supplies and triacs. Its accuracy spans a wide range of input levels and temperatures. The ensured accuracy of ≤±0.5% and ≤10 μV output offset result from the latest Analog Devices, Inc., technology. The crest factor error is <0.5% for CF values between 1 and 10.
The AD8436 delivers instant true rms results at less cost than misleading peak, averaging, or digital solutions. There is no programming expense or processor overhead to consider, and the 4 mm × 4 mm package easily fits into those tight applications.
On-board buffer amplifiers enable the widest range of options for any rms-to-dc converter available, regardless of cost. For minimal applications, only a single external averaging capacitor is required. The built-in high impedance FET buffer provides an interface for external attenuators, frequency compensation, or driving low impedance loads. A matched pair of internal resistors enables an easily configurable gain-of-two or more, extending the usable input range even lower. The low power, precision input buffer makes the AD8436 attractive for use in portable multi- meters and other battery-powered applications. The precision dc output buffer offers extremely low offset voltages, thanks to bias current cancellation.
Unlike digital solutions, the AD8436 has no switching circuitry limiting performance at high or low amplitudes (see Figure 2). A usable response of <100 μV and >3 V extends the dynamic range with no external scaling, accommodating the most demanding low signal conditions.
The AD8436 operates from single or dual supplies of ±2.4 V (4.8 V) to ±18 V (36 V). A and J grades are available in a compact 4 mm × 4 mm, 20-lead chip-scale package. The operating temperature ranges are −40°C to 125°C and 0°C to 70°C.
The AD8436 is a good choice for remote, portable battery-powered instrumentation, energy and automotive applications where limited board space and outdoor environments are considerations.
AD8436主要特性:
Computes true rms value instantly
Accuracy: ±10 μV ± 0.5% of reading
Wide dynamic input range
100 μV rms to 3 V rms (8.5 V p-p) full-scale input range
Larger inputs with external scaling
Wide bandwidth:
1 MHz for −3 dB (300 mV)
65 kHz for additional 1% error
Zero converter dc output offset
No residual switching products
Specified at 300 mV rms input
Accurate conversion with crest factors up to 10
Low power: 300 μA typical at ±2.4 V
Fast settling at all input levels
High-Z FET separately powered input buffer
RIN ≥ 1012 Ω, CIN ≤ 2 pF
Precision dc output buffer
Wide supply range
Dual: ±2.4 V to ±18 V
Single: 4.8 V to 36 V
Small size: 4 mm × 4 mm package
ESD protected
图1。AD8436功能方框图
图2。AD8436 RMS核方框图
图3。波峰因素测试电路图
图4。AD8436典型应用电路
AD8436-EVALZ评估板
The AD8436-EVALZ provides a platform to evaluate AD8436 performance. The board is fully assembled, tested and ready to use after the power and signal sources are connected. Figure 45 is a photograph of the board. Signal connections are located on the primary and secondary sides, with power and ground on the inner layers.
The AD8436-EVALZ offers many options, without sacrificing simplicity. The board is tested and shipped with a 10 μF averaging capacitor (CAVG), 3.3 μF low-pass filter capacitor (C8) and a 0.1 μF (COPT) capacitor to optimize crest factor performance. To evaluate minimum cost applications, remove C8 and COPT.
图5。AD8436-EVALZ评估板外形图
图6。AD8436-EVALZ评估板电路图
图7。AD8436-EVALZ评估板元件布局图
详情请见:
http://www.analog.com/static/imported-files/data_sheets/AD8436.pdf
本文地址:https://www.eechina.com/thread-73602-1-1.html     【打印本页】
Liming 发表于 2011-9-17 00:27:42
ADI推出一款集成式真RMS-to-DC:AD8436
Analog Devices, Inc.(ADI),最近推出一款集成式真 RMS-to-DC AD8436,它提供一流的100 µV至3 V可用动态范围,能够以高精度测量极低的信号电平,且建立时间内无压降。
       AD8436是一款精密单芯片RMS-to-DC转换器(http://www.analog.com/zh/pr0816/ad8436),其交流转换精度优于±0.5%,各种不同输入值的建立时间相同,使得转换速率恒定不变,同时可即刻显示交流输入几乎为零以及高电平交流输入时的转换结果。AD8436不受温度、波峰因数和电源电压变化的影响。转换器输出的零直流失调电压可简化校准程序。它集成FET输入和精密直流缓冲放大器,功耗仅300 uA,采用紧凑型4 mm x 4 mm封装。AD8436 特别适合需要考虑有限的电路板空间和室外应用环境的远程便携电池供电仪器、能源和汽车应用。
  RMS(均方根)是交流和直流信号幅度的基本量度,与简单的均值方法相比,这是一种更好的信号功率测量方法。RMS-to-DC 转换器适合必须实现交流/直流信号低功耗精密测量的应用场合。借助 AD8436 的片上系统设计,可算出 RMS 的精确直流等效值,并在整个输入范围内提供一定水平的线性度和精度,有助于工程师设计出90 dB动态范围的系统。
  AD8436 将波峰因数扩展到10(约为目前业界标准数字解决方案的两倍),最大程度地保证精度。它特别适用于高跃迁信号,可用于目前使用 ADI 公司的AD736和AD737等低功耗、真 RMS-to–DC 转换器的设计,使性能有所提升。该器件经激光调整,具有300mV的 RMS 输入,采用双电源和单电源供电。AD8436 是第一款能够在-40°C至125°C的扩展工业温度范围内工作的RMS-to-DC转换器,同时还提供0°C至70°C温度范围的版本。
  AD8436精密、低功耗、单芯片真均方根直流转换器的主要特性:
即时计算真有效值
任意输入电平下的建立时间均快速、恒定
宽可用动态范围:100 uV RMS至3 VRMS (8.5 V p-p) 满量程
输入频率范围:65 kHz,额外误差1%
低功耗:±2.4 V时典型值为300 µA
精度:±10 μV ,最大读数的0.5%
片上系统包括带精密增益设置电阻的FET输入缓冲和输出缓冲
电源电压范围:
双电源:+/-2.4 V至+/-18 V
单电源:4.8 V至36 V
  AD8436的配套产品包括24位Σ-Δ型ADC AD7190和微功耗、高精度基准电压源ADR3433,适合低噪声、低功耗精密应用。
