发表于 2014-4-27 14:29:57
显示全部楼层
bleaz 发表于 2010-7-31 11:18
谢谢!
我生成的封装 焊盘没加进到封装中去。什么原因?allegro.jrl,1记录中出现错误提示。
\i (00:00:06) pick -3.55 5.715
\t (00:00:06) last pick: -3.5500 5.7150
\e (00:00:06) ERROR(SPMHAP-2): No padstack specified.
allegro.jrl,1全文记录如下:
\t (00:00:01) allegro 16.5 P003 (v16-5-13C) i86
\t (00:00:01) Journal start - Sun Apr 27 14:06:36 2014
\t (00:00:01) Host=WINDOWS-PC User=windows Pid=5456 CPUs=4
\t (00:00:01)
\t (00:00:04) Starting new design...
\i (00:00:04) trapsize 955
\i (00:00:04) trapsize 929
\i (00:00:04) trapsize 959
\i (00:00:04) trapsize 971
\i (00:00:04) trapsize 1728
\i (00:00:04) replay soj127p866x356-20n.scr
\i (00:00:04) version 16.5
\t (00:00:04) Script version: 16.5
\i (00:00:04) setwindow pcb
\i (00:00:04) new
\i (00:00:04) newdrawfillin soj127p866x356-20n.dra 'Package Symbol'
\t (00:00:05) Starting new design...
\i (00:00:05) trapsize 971
\i (00:00:05) trapsize 929
\i (00:00:05) trapsize 959
\i (00:00:05) trapsize 986
\i (00:00:05) trapsize 1728
\i (00:00:05) setwindow Form.vf_vis
\i (00:00:05) FORM vf_vis 1 all_colorvisible YES
\i (00:00:05) FORM vf_vis 2 all_colorvisible YES
\i (00:00:05) setwindow pcb
\i (00:00:05) Color
\i (00:00:05) setwindow form.cvf_main
\i (00:00:05) FORM cvf_main class_list Geometry
\i (00:00:05) setwindow Form.cvf_main
\i (00:00:05) FORM cvf_main class_list Components
\i (00:00:05) FORM cvf_main all_visible1 YES
\i (00:00:05) FORM cvf_main all_visible2 YES
\i (00:00:05) FORM cvf_main all_visible3 YES
\i (00:00:05) FORM cvf_main all_visible5 YES
\i (00:00:05) FORM cvf_main package_geometry/pin_number/visible NO
\i (00:00:05) FORM cvf_main class_list Stack-Up
\i (00:00:05) FORM cvf_main ok
\i (00:00:05) generaledit
\i (00:00:05) prmed
\i (00:00:05) setwindow Form.prmedit
\i (00:00:05) FORM prmedit design
\i (00:00:05) FORM prmedit units Millimeter
\e (00:00:05) Change may cause round-off; run dbcheck.
\i (00:00:05) FORM prmedit accuracy 4
\i (00:00:05) FORM prmedit size Other
\i (00:00:05) FORM prmedit x -5
\i (00:00:05) FORM prmedit y -5
\i (00:00:05) FORM prmedit width 32
\i (00:00:05) FORM prmedit height 32
\i (00:00:05) FORM prmedit x -16
\i (00:00:05) FORM prmedit y -16
\i (00:00:05) FORM prmedit done
\w (00:00:06) WARNING(SPMHUT-48): Scaled value has been rounded off.
\i (00:00:06) trapsize 3252
\t (00:00:06) Performing DRC...
\t (00:00:06) No DRC errors detected.
\i (00:00:06) setwindow pcb
\i (00:00:06) add pin
\i (00:00:06) setwindow Form.mini
\i (00:00:06) FORM mini pad_name b245_65
\e (00:00:06) ERROR(SPMHAP-3): Problem loading 'b245_65.pad'.
\e (00:00:06) ERROR(SPMHA1-161): Cannot open the design database file ... run standalone dbdoctor on the file.
\i (00:00:06) FORM mini next_pin_number 1
\i (00:00:06) rotate
\t (00:00:06) Pin rotated by '0.000' degrees.
\i (00:00:06) iangle 0
\t (00:00:06) last pick: 0.0000 0.0000
\i (00:00:06) FORM mini pintype_mechanical NO
\i (00:00:06) FORM mini offsetx 0
\i (00:00:06) FORM mini offsety 0
\i (00:00:06) pick -3.55 4.445
\t (00:00:06) last pick: -3.5500 4.4450
\i (00:00:06) pick -3.55 3.175
\t (00:00:06) last pick: -3.5500 3.1750
\i (00:00:06) pick -3.55 1.905
\t (00:00:06) last pick: -3.5500 1.9050
\i (00:00:06) pick -3.55 0.635
\t (00:00:06) last pick: -3.5500 0.6350
\i (00:00:06) pick -3.55 -0.635
\t (00:00:06) last pick: -3.5500 -0.6350
\i (00:00:06) pick -3.55 -1.905
\t (00:00:06) last pick: -3.5500 -1.9050
\i (00:00:06) pick -3.55 -3.175
\t (00:00:06) last pick: -3.5500 -3.1750
\i (00:00:06) pick -3.55 -4.445
\t (00:00:06) last pick: -3.5500 -4.4450
\i (00:00:06) pick -3.55 -5.715
\t (00:00:06) last pick: -3.5500 -5.7150
\i (00:00:06) pick 3.55 -5.715
\t (00:00:06) last pick: 3.5500 -5.7150
\i (00:00:06) pick 3.55 -4.445
\t (00:00:06) last pick: 3.5500 -4.4450
\i (00:00:06) pick 3.55 -3.175
\t (00:00:06) last pick: 3.5500 -3.1750
\i (00:00:06) pick 3.55 -1.905
\t (00:00:06) last pick: 3.5500 -1.9050
\i (00:00:06) pick 3.55 -0.635
\t (00:00:06) last pick: 3.5500 -0.6350
\i (00:00:06) pick 3.55 0.635
\t (00:00:06) last pick: 3.5500 0.6350
\i (00:00:06) pick 3.55 1.905
\t (00:00:06) last pick: 3.5500 1.9050
\i (00:00:06) pick 3.55 3.175
\t (00:00:06) last pick: 3.5500 3.1750
\i (00:00:06) pick 3.55 4.445
\t (00:00:06) last pick: 3.5500 4.4450
\i (00:00:06) pick 3.55 5.715
\t (00:00:06) last pick: 3.5500 5.7150
\i (00:00:06) done
\t (00:00:06) Exiting from Add Pin.
\i (00:00:06) add line
\i (00:00:06) FORM mini class PACKAGE GEOMETRY
\i (00:00:06) FORM mini subclass DISPLAY_TOP
\i (00:00:06) FORM mini line_width 0.001
\i (00:00:06) pick -3.81 -6.5
\t (00:00:06) last pick: -3.8100 -6.5000
\i (00:00:06) pick -3.81 6.5
\t (00:00:06) last pick: -3.8100 6.5000
\i (00:00:06) pick 3.81 6.5
\t (00:00:06) last pick: 3.8100 6.5000
\i (00:00:06) pick 3.81 -6.5
\t (00:00:06) last pick: 3.8100 -6.5000
\i (00:00:06) done
\i (00:00:06) shape add
\i (00:00:06) FORM mini subclass DFA_BOUND_TOP
\i (00:00:06) FORM mini dyns_fill_type Static solid
\i (00:00:06) FORM mini dyns_grid None
\i (00:00:06) FORM mini dyns_lock_mode Line
\i (00:00:06) pick -5.05 -6.75
\t (00:00:06) last pick: -5.0500 -6.7500
\i (00:00:06) pick -5.05 6.75
\t (00:00:06) last pick: -5.0500 6.7500
\i (00:00:06) pick 5.05 6.75
\t (00:00:06) last pick: 5.0500 6.7500
\i (00:00:06) pick 5.05 -6.75
\t (00:00:06) last pick: 5.0500 -6.7500
\i (00:00:06) done
\i (00:00:06) FORM mini subclass PLACE_BOUND_TOP
\i (00:00:06) done
\i (00:00:06) add circle
\t (00:00:06) Pick center point of the circle.
\i (00:00:06) FORM mini line_width 0.05
\i (00:00:06) pick 0 0
\t (00:00:06) Pick a perimeter point on the circle.
\i (00:00:06) pick 0.35 0
\t (00:00:06) last pick: 0.3500 0.0000
\i (00:00:06) done
\i (00:00:06) pick 0 -0.5
\t (00:00:06) last pick: 0.0000 -0.5000
\i (00:00:06) pick 0 0.5
\t (00:00:06) last pick: 0.0000 0.5000
\i (00:00:06) done
\i (00:00:06) pick -0.5 0
\t (00:00:06) last pick: -0.5000 0.0000
\i (00:00:06) pick 0.5 0
\t (00:00:06) last pick: 0.5000 0.0000
\i (00:00:06) done
\i (00:00:06) FORM mini subclass ASSEMBLY_TOP
\i (00:00:06) FORM mini line_width 0.1
\i (00:00:06) pick -1.325 5.4
\t (00:00:06) last pick: -1.3250 5.4000
\i (00:00:06) pick -0.825 5.4
\t (00:00:06) last pick: -0.8250 5.4000
\i (00:00:06) done
\i (00:00:06) pick -3.76 -6.4
\t (00:00:06) last pick: -3.7600 -6.4000
\i (00:00:06) pick -3.76 6.4
\t (00:00:06) last pick: -3.7600 6.4000
\i (00:00:06) pick 3.76 6.4
\t (00:00:06) last pick: 3.7600 6.4000
\i (00:00:06) pick 3.76 -6.4
\t (00:00:06) last pick: 3.7600 -6.4000
\i (00:00:06) done
\i (00:00:06) FORM mini subclass SILKSCREEN_TOP
\i (00:00:06) FORM mini line_width 0.2
\i (00:00:06) pick -2 -6.4
\t (00:00:06) last pick: -2.0000 -6.4000
\i (00:00:06) pick -2 6.4
\t (00:00:06) last pick: -2.0000 6.4000
\i (00:00:06) pick 2 6.4
\t (00:00:06) last pick: 2.0000 6.4000
\i (00:00:06) pick 2 -6.4
\t (00:00:06) last pick: 2.0000 -6.4000
\i (00:00:06) done
\i (00:00:06) FORM mini line_width 0.5
\i (00:00:06) pick -1 5.4
\t (00:00:06) last pick: -1.0000 5.4000
\i (00:00:06) pick -0.75 5.4
\t (00:00:06) last pick: -0.7500 5.4000
\i (00:00:06) done
\i (00:00:06) FORM mini line_width 0.25
\i (00:00:06) pick -4.5 6.55
\t (00:00:06) last pick: -4.5000 6.5500
\i (00:00:06) pick -4.375 6.55
\t (00:00:06) last pick: -4.3750 6.5500
\i (00:00:06) done
\i (00:00:06) package_height
\i (00:00:06) pick grid 0 0
\i (00:00:06) FORM mini height_max 3.56mm
\i (00:00:06) done
\e (00:00:06) Form field label not found
\i (00:00:06) Label refdes
\t (00:00:07) Pick text location.
\i (00:00:07) setwindow Form.mini
\i (00:00:07) FORM mini text_block 3
\i (00:00:07) FORM mini angle 90
\i (00:00:07) FORM mini mirror NO
\i (00:00:07) FORM mini text_justification Center
\i (00:00:07) FORM mini class REF DES
\i (00:00:07) FORM mini subclass ASSEMBLY_TOP
\i (00:00:07) setwindow pcb
\i (00:00:07) pick 0 0.75
\t (00:00:07) last pick: 0.0000 0.7500
\t (00:00:07) Enter text string.
\i (00:00:07) Text REF
\i (00:00:07) done
\i (00:00:07) Label refdes
\i (00:00:07) FORM mini subclass SILKSCREEN_TOP
\i (00:00:07) done
\i (00:00:07) Label device
\i (00:00:07) FORM mini class DEVICE TYPE
\i (00:00:07) Text DEV
\i (00:00:07) done
\i (00:00:07) save
\t (00:00:07) Symbol 'soj127p866x356-20n.psm' created.
\i (00:00:07) exit
\t (00:00:07) Journal end - Sun Apr 27 14:06:42 2014
