ESP8266 系列模组是安信可(Ai-thinker)公司采用乐鑫ESP8266芯片开发的一系列wifi 模组模块。
ESP8266系列模块现在主要包括以下类型:
ESP-01 包括两个版本,一个是篮色版,一个是黑色版本的,功能一样,Pin脚一样,只是主板颜色不同,蓝色是老版产品,目前AI-thinker已经停产这种版本,但是市场上还是有一些在售产品,后期ESP-01都是黑色版本的。ESP-01 共接出 8 个接口 ,ESP-01 贴片式模
组的外观尺寸为14.3mm*24.8mm*3mm。该模组采用的是容量为 1MB, 封装为SOP-210 mil 的 SPI Flash。模组使用的是3 DBi 的PCB 板载天线。
ESP8266 series modules As following types:
ESP - 01 includes two versions, one Blue version and a black version, functions and Pin is same, only the mainboard.it is different the color of mainboard . the AI - thinker have shut down Blue version now, ESP-01 are altogether 8 pin
counts, The external size of the module is 14.3mm*24.8mm*3mm .The type of Flash integrated in this module is an SPI flash, the capacity of which is 1 MB,the package size of which is SOP-210mil.
The antenna applied on this module is a 3DBi PCB-on-board antenna.
ESP-02 共接出8个接口,ESP-02 贴片式模组的外观尺寸为 14.9mm*16.3mm *3mm。该模组采用的是容量为 1MB, 封装为 SOP-210 mil 的 SPI Flash。
ESP-02 are altogether 8 pin counts, The external size of the module is 14.9mm *16.3 mm *3mm .The type of Flash integrated in this module is an SPI flash, the capacity of which is 1 MB,the package size of which is SOP-210mil.
ESP-03 共接出 14个接口,ESP-03 贴片式模组的外观尺寸为17.3mm*12.1mm*3mm。该模组采用的是容量为1MB, 封装为SOP-210 mil 的 SPI Flash。模组使用的是陶瓷板载天线。
ESP-03 are altogether 14 pin counts, The external size of the module is 17.3mm *12.1 mm *3mm .The type of Flash integrated in this module is an SPI flash, the capacity of which is 1 MB,the package size of which is SOP-210mil.
The antenna applied on this module is a ceramic antenna.
ESP-04 共接出14个接口,ESP-04 贴片式模组的外观尺寸为 14.7mm*12.1mm *3mm。该模组采用的是容量为 1MB, 封装为 SOP-210 mil 的 SPI Flash。
ESP-04 are altogether 14 pin counts, The external size of the module is 14.7mm *12.1 mm *3mm .The type of Flash integrated in this module is an SPI flash, the capacity of which is 1 MB,the package size of which is SOP-210mil.
ESP-05 共接出 5个接口,ESP-05 贴片式模组的外观尺为 14.2mm*14.2mm *3mm。该模组采用的是容量为 1MB, 封装为 SOP-210 mil 的 SPI Flash。
ESP-05 are altogether 5 pin counts, The external size of the module is 14.2mm *14.2 mm *3mm .The type of Flash integrated in this module is an SPI flash, the capacity of which is 1 MB,the package size of which is SOP-210mil.
ESP-06共接出 5个接口,ESP-06E 贴片式模组的外观尺寸为 16.2mm*13.2mm *3mm。该模组采用的是容量为 1MB, 封装为 SOP-210 mil 的 SPI Flash。
ESP-06 are altogether 5 pin counts, The external size of the module is 16.2mm *13.2 mm *3mm .The type of Flash integrated in this module is an SPI flash, the capacity of which is 1 MB,the package size of which is SOP-210mil.
ESP-7共接出 5个接口,ESP-07 贴片式模组的外观尺寸为 16mm*21.2mm *3mm。该模组采用的是容量为 1MB, 封装为 SOP-210 mil 的 SPI Flash。配有陶瓷天线。
ESP-07 are altogether 5 pin counts, The external size of the module is 16mm *21.2 mm *3mm .The type of Flash integrated in this module is an SPI flash, the capacity of which is 1 MB,the package size of which is SOP-210mil.
ESP-08共接出 5个接口,ESP-08 贴片式模组的外观尺寸为 16mm*18.5mm *3mm。该模组采用的是容量为 1MB, 封装为 SOP-210 mil 的 SPI Flash。
ESP-08 are altogether 5 pin counts, The external size of the module is 16mm *18.5 mm *3mm .The type of Flash integrated in this module is an SPI flash, the capacity of which is 1 MB,the package size of which is SOP-210mil.
ESP-09共接出 20个接口,ESP-09 贴片式模组的外观尺寸为 10mm*10mm *3mm。该模组采用的是容量为 1MB, 封装为 SOP-210 mil 的 SPI Flash。
ESP-09 are altogether 20 pin counts, The external size of the module is 10mm *10 mm *3mm .The type of Flash integrated in this module is an SPI flash, the capacity of which is 1 MB,the package size of which is SOP-210mil.
ESP-10共接出 5个接口,ESP-10 贴片式模组的外观尺寸为 16mm*18.5mm *3mm。该模组采用的是容量为 1MB, 封装为 SOP-210 mil 的 SPI Flash。
ESP-10 are altogether 5 pin counts, The external size of the module is 16mm *18.5 mm *3mm .The type of Flash integrated in this module is an SPI flash, the capacity of which is 1 MB,the package size of which is SOP-210mil.
ESP-11共接出 8个接口,ESP-11 贴片式模组的外观尺寸为 16mm*18.5mm *3mm。该模组采用的是容量为 1MB, 封装为 SOP-210 mil 的 SPI Flash。
ESP-11 are altogether 8 pin counts, The external size of the module is 16mm *18.5 mm *3mm .The type of Flash integrated in this module is an SPI flash, the capacity of which is 1 MB,the package size of which is SOP-210mil.
ESP-12 共接出 18 个接口,ESP-12 贴片式模组的外观尺?寸为 16mm*24mm *3mm。该模组采用的是容量为 4MB, 封装为 SOP-210 mil 的 SPI Flash。模组使用的是 3 DBi 的 PCB 板载天线。
ESP-12 are altogether 18 pin counts, The external size of the module is 16mm *18.5 mm *3mm .The type of Flash integrated in this module is an SPI flash, the capacity of which is 4 MB,the package size of which is SOP-210mil.
ESP-12E 共接出 16 个接口,ESP-12E贴片式模组的外观尺寸为 16mm*24mm *3mm。该模组采用的是容量为 4MB, 封装为 SOP-210 mil 的 SPI Flash。模组使用的是 3 DBi 的 PCB 板载天线。
ESP-12E are altogether 16 pin counts, The external size of the module is 16mm *24 mm *3mm .The type of Flash integrated in this module is an SPI flash, the capacity of which is 4 MB,the package size of which is SOP-210mil.
ESP-12F 共接出 18 个接口,ESP-12F 贴片式模组的外观尺寸为 16mm*24mm *3mm。该模组采用的是容量为 4MB, 封装为 SOP-210 mil 的 SPI Flash。模组使用的是 3 DBi 的 PCB 板载天线。
ESP-12F are altogether 18 pin counts, The external size of the module is 16mm *24 mm *3mm .The type of Flash integrated in this module is an SPI flash, the capacity of which is 4 MB,the package size of which is SOP-210mil.
ESP-13 共接出 18 个接口,ESP-13 贴片式模组的外观尺寸为18mm*20mm *3mm。该模组采用的是容量为 4MB, 封装为 SOP-150 mil 的 SPI Flash。模组使用的是 3 DBi 的 PCB 板载天线。
ESP-13 are altogether 18 pin counts, The external size of the module is 18mm *20 mm *3mm .The type of Flash integrated in this module is an SPI flash, the capacity of which is 4 MB,the package size of which is SOP-210mil.
ESP-14 共接出 22 个接口,ESP-14 贴片式模组的外观尺寸为16mm*24mm *3mm。该模组采用的是容量为1MB, 内置STM8003 MCU和ESP8266 WIFI芯片。ESP8266-14同时支持贴片和DIP插件两种方式,采用2.0的间隔 。
ESP-14 are altogether 18 pin counts, The external size of the module is 16mm *24 mm *3mm .the capacity of which is 1MB.ESP-14 module has a built-in powerful STMs8003F3P6 chips and wifi ESP8266, pick out all the pins, serial port can
connected tthe serial port of the ESP8266, users can write STM8 program, through the AT command control WIFI Internet capability.
产品试用:
QQ :2154448623
Email :nicole@aithinker.com
Mob:13418538097
PS:如果专注出口联系此QQ可以提供外文资料翻译,以及一些其他外贸援助支持。 |
