楼主: admin
【公社开通FTP服务】FTP密码将不定期更改!
发表于 2015-3-4 17:56:50 | 显示全部楼层
找mentor软件中,谢谢
发表于 2015-3-4 19:47:09 | 显示全部楼层
多谢。。。。。。
发表于 2015-3-5 11:39:09 | 显示全部楼层
我上去看看
发表于 2015-3-5 15:26:14 | 显示全部楼层
怎么看不到
发表于 2015-3-8 11:08:56 | 显示全部楼层
good good good !!!
发表于 2015-3-10 02:01:33 | 显示全部楼层
ganxie
发表于 2015-3-10 15:39:52 | 显示全部楼层
发表于 2015-3-10 21:00:06 | 显示全部楼层
先看看!
发表于 2015-3-11 09:02:50 | 显示全部楼层
好的,看看
发表于 2015-3-13 15:21:53 | 显示全部楼层
资料太赞了,感谢无私贡献
发表于 2015-3-18 04:19:57 | 显示全部楼层
谢谢版主辛勤付出!
发表于 2015-3-18 04:44:57 | 显示全部楼层
服务器现在还开着么,怎没连上涅, 我用的cuteftp
STATUS:>          [3/17/2015 4:41:31 PM] Getting listing ""...
STATUS:>          [3/17/2015 4:41:31 PM] Connecting to FTP server... 113.11.198.49:21 (ip = 113.11.198.49)...
ERROR:>           [3/17/2015 4:41:52 PM] The connection failed due to an error or timeout.
                1) Verify that the destination IP address is correct.
                2) Increase the connection timeout threshold under Global Settings | Connection.
                3) Switch to the opposite data connection type (PASV or PORT) under Site Settings | Type tab.
                4) Verify that the problem is not local by trying to connect to an alternate server.
                5) If a server name was used, verify it resolves to the correct address.
                6) If using a local server table for server name resolution, check to see that it doesn't resolve to an obsolete address.
                7) Try pinging the address.
                8) If you are using a router, verify the router is up and running (check by pinging it and then ping an address outside of the router).
                9) Do a traceroute to the destination to verify all routers along the connection path are operational.
                10) Verify that your subnet mask is setup properly.
                11) Verify that your local software or hardware firewall is not blocking outbound connections originating from CuteFTP.
                12) Verify that your anti-virus software is not at fault (try disabling it).
发表于 2015-3-18 10:02:33 | 显示全部楼层
xuexixuxi
发表于 2015-3-21 10:48:21 | 显示全部楼层
看看有没有我要的资料
发表于 2015-3-22 23:34:03 | 显示全部楼层
谢谢分享
发表于 2015-3-23 13:24:56 | 显示全部楼层
xxxxxxxxx
发表于 2015-3-23 21:40:24 | 显示全部楼层
发表于 2015-3-23 23:43:26 | 显示全部楼层
快捷方式来房间
发表于 2015-3-24 16:48:51 | 显示全部楼层
谢谢
发表于 2015-3-26 03:16:02 | 显示全部楼层
强力围观插入。。
