查看: 2035|回复: 0
[供应] MKL25Z128开发板freescale CortexM0+开发板USBHost/device 可接U盘
发表于 2013-8-5 17:38:25 | 显示全部楼层 |阅读模式
盈钰电子产品——MKL25Z128开发板闪亮登场,支持USBHost、Device。现已批量供应啦,欢迎订购!
开发板的物理尺寸:44x55.5mm
处理器主要参数
Operating Characteristics
Voltage range: 1.71 to 3.6 V
Flash write voltage range: 1.71 to 3.6 V
Temperature range (ambient): -40 to 105°C
Performance
Up to 48 MHz ARM? Cortex-M0+ core
• Memories and memory interfaces
– Up to 128 KB program flash memory
– Up to 16 KB RAM
• Clocks
– 32 kHz to 40 kHz or 3 MHz to 32 MHz crystal oscillator
– Multi-purpose clock source
• System peripherals
– Nine low-power modes to provide power optimization based on application requirements
– 4-channel DMA controller, supporting up to 63 request sources
– COP Software watchdog
– Low-leakage wakeup unit
– SWD interface and Micro Trace buffer
– Bit Manipulation Engine (BME)
Security and integrity modules
80-bit unique identification (ID) number per chip
Human-machine interface
Low-power hardware touch sensor interface (TSI)
General-purpose input/output
Analog modules
16-bit SAR ADC
12-bit DAC
Analog comparator (CMP) containing a 6-bit DAC and programmable reference input
Timers
Six channel Timer/PWM (TPM)
Two 2-channel Timer/PWM (TPM)
Periodic interrupt timers
16-bit low-power timer (LPTMR)
Real-time clock
Communication interfaces
USB full-/low-speed On-the-Go controller with onchip transceiver and 5 V to 3.3 V regulator
Two 8-bit SPI modules
Two I2C modules
One low power UART module
Two UART modules
开发板的硬件配置
USB2.0(全速内置PHY)从设备接口
USB2.0(全速内置PHY)主设备接口(主、从共用)
USB转串口
RGB LED
两个功能按键
一个可调电阻
所有的I/O引出到板边,部分管脚根据功能集中排列
提供的测试程序
装箱清单
MKL25Z128开发板  1块
高速MiniUSB线       1条
开发光盘:附开发环境及所有相关例程,还有相关的手册资料等。
盈钰工作室:http://www.elechome.com
http://elechome.21ic.org
E-mail:senxin79@126.com
联系QQ:690971654
电话:020-61392789
手机:15360803087
淘宝店:http://mcuworld.taobao.com/
