ADI ADP1607 2MHz同步升压DC-DC转换器设计方案
发布时间:2013-1-19 19:43    发布者:1770309616
关键词: ADI , ADP1607 , DC-DC , 转换器
ADI公司的ADP1607是一款高效、同步、固定频率、升压型DC/DC转换器,主要应用于便携设备,输出电压可调范围为1.8V至3.3V。该芯片具有2Mhz的固定输出频率、小封装、同步矫正、内部补偿、内部限流、输出隔离、热关断、优秀的瞬态响应和外围器件少等特点。本文通过总结ADP1607器件的特点,介绍器件、特性、应用方向及内部结构框图,并给参考设计实例主要特性、原理图、制板图及元器件清单。
The ADP1607 is a high efficiency, synchronous, fixed frequency, step-up dc-to-dc switching converter with an adjustable output voltage between 1.8 V and 3.3 V for use in portable applications.
The 2 MHz operating frequency enables the use of small footprint, low profile external components. Additionally, the synchronous rectification, internal compensation, internal fixed current limit, and current mode architecture allow for excellent transient response and a minimal external part count.
Other key features include fixed PWM and light load PFM mode options, true output isolation, thermal shutdown (TSD), and logic controlled enable. Available in a lead-free, thin, 6-lead LFCSP package, the ADP1607 is ideal for providing efficient power conversion in portable devices.
ADP1607主要特性:
Up to 96% efficiency
0.8 V to VOUT input voltage range
Low 0.9 V input start-up voltage
1.8 V to 3.3 V output voltage range
23 μA quiescent current
Fixed PWM and light load PFM mode options
Synchronous rectification
True shutdown output Isolation
Internal soft start, compensation, and current limit
2 mm × 2 mm, 6-lead LFCSP
Compact solution size
ADP1607应用:
1-cell and 2-cell alkaline and NiMH/NiCd powered devices
Portable audio players, instruments, and medical devices
Solar cell applications
Miniature hard disk power supplies
Power LED status indicators
图1. ADP1607方框图
ADP1607参考设计主要特性:
Fixed 2 MHz PWM and light load PFM mode options
Auto PFM/PWM transition modes (ADP1607-EVALZ)
PWM mode only (ADP1607-001-EVALZ)
Jumper for enable/shutdown control
R1 and R2 selected for VOUT = 3.3 V output voltages
ADP1607设计原理图:
图2. ADP1607设计原理图
ADP1607设计方案材料清单:
PCB元件布局图:
ADP1067.pdf (452.05 KB)
UG-488.pdf (151.56 KB)
(网络)
本文地址:https://www.eechina.com/thread-109358-1-1.html     【打印本页】
