查看: 1552|回复: 0
25LC080BT-I/ST芯片解密技术资料
发表于 2012-11-2 15:47:38 | 显示全部楼层 |阅读模式
 Features
  Max. clock 10 MHz
  Low-power CMOS technology
  1024 x 8-bit organization
  16 byte page (‘A’ version devices)
  32 byte page (‘B’ version devices)
  Write cycle time: 5 ms max.
  Self-timed ERASE and WRITE cycles
  Block write protection
  - Protect none, 1/4, 1/2 or all of array
  Built-in write protection
  - Power-on/off data protection circuitry
  - Write enable latch
  - Write-protect pin
  Sequential read
  High reliability
  - Endurance: 1,000,000 erase/write cycles
  - Data retention: > 200 years
  - ESD protection: > 4000V
  Pb-free and RoHS compliant
  Temperature ranges supported;
  Pin Function Table
  Description
  The Microchip Technology Inc. 25AA080A/B,
  25LC080A/B (25XX080A/B
  ) are 8 Kbit Serial
  Electrically Erasable PROMs. The memory is accessed
  via a simple Serial Peripheral Interface (SPI)
  compatible serial bus. The bus signals required are a
  clock input (SCK) plus separate data in (SI) and data
  out (SO) lines. Access to the device is controlled
  through a Chip Select (CS) input.
  Communication to the device can be paused via the
  hold pin (HOLD). While the device is paused, transi-
  tions on its inputs will be ignored, with the exception of
  chip select, allowing the host to service higher priority
  interrupts.
  The 25XX080A/B is available in standard packages
  including 8-lead PDIP and SOIC, and advanced
  packaging including 8-lead MSOP, and 8-lead TSSOP.
  All packages are Pb-free and RoHS compliant.
  Package Types (not to scale)
  Part Number VCC Range Page Size Temp. Ranges Packages
  25LC080A 2.5-5.5V 16 Byte I, E P, SN, ST, MS
  25AA080A 1.8-5.5V 16 Byte I P, SN, ST, MS
  25LC080B 2.5-5.5V 32 Byte I, E P, SN, ST, MS
  25AA080B 1.8-5.5V 32 Byte I P, SN, ST, MS
  - Industrial (I): -40°Cto +85°C
  - Automotive (E): -40°C to +125°C
  Name Function
  CS Chip Select Input
  SO Serial Data Output
  WP Write-Protect
  VSS Ground
  SI Serial Data Input
  SCK Serial Clock Input
  HOLD Hold Input
  VCC Supply Voltage
本资料由www.atmeldaili.com整理提供。
