IR IRAUDAMP9 1700W数字D类音频功率放大参考设计
发布时间:2012-7-18 11:10
发布者:1770309616
IR公司的IRAUDAMP9是采用IRS2092S和IRFB4227的单路1.7 kW / 2-Ω 数字D类音频功率放大参考设计,输出功率1.7kW(2 Ω 负载, 1kHz, THD+N=10%),THD+N失真0.07%(@ 600W, 2Ω),效率97%(@ 1.7 kW, 2Ω),具有多种输出保护特性如OCP,OVP,UVP,DCP和OTP,主要用于专业音响放大器,扬声器,有源亚低音,功率放大器,汽车音频放大器和乐器放大器.本文介绍了AUIRS2092主要特性,方框图,典型应用电路,以及D类音频功率放大器参考设计IRAUDAMP9功能框图,主板和子板电路图以及材料清单,PCB布局图. The AUIRS2092 is a high voltage, high performance Class D audio amplifier driver with PWM modulator and protection. In conjunction with two external MOSFET and a few external components, a complete Class D audio amplifier with protection can be realized. International Rectifier’s proprietary noise isolation technology allows high current gate drive stage and high speed low noise error amplifier reside on a single small silicon die.Open elements of PWM modulator section allow flexible PWM topology implementation. AUIRS2092主要特性: • Integrated analog input Class D audio amplifier driver in a small 16 pin package • Floating inputs enable easy half bridge implementation • Programmable bidirectional over-current protection with self-reset function • Programmable preset deadtime for improved THD performances • Start and stop click noise reduction • High noise immunity • ±100 V ratings deliver up to 500 W in output power • Operates up to 800 kHz • Leadfree, RoHS compliant • Automotive Qualified† AUIRS2092典型应用: • Automotive mini component stereo systems • Automotive powered speaker systems • Automotive audio power amplifiers 图1.AUIRS2092方框图 图2.AUIRS2092典型连接电路图 图2.AUIRS2092 OTA输入噪音电压测量电路图 采用IRS2092S和IRFB4227的1.7 kW / 2-Ω单路D类音频功率放大器参考设计IRAUDAMP9 The IRAUDAMP9 reference design is a single-channel 1.7-kW ( @ 2?load) half-bridge Class D audio power amplifier. This reference design demonstrates how to use the IRS2092S Class D audio controller and external gate buffer, to implement protection circuits, and design an optimum PCB layout using the IRFB4227 (x 2 Pairs) TO-220 MOSFETs. This reference design may require additional heatsink or fan for normal operation (one-eighth of continuous rated power). The reference design provides all the required housekeeping power supplies for ease of use. The 1-channel design is capable of delivering higher than its rated power with provision of larger heat sink ( Rth <2?C / W). 参考设计主要特性: Output Power: 1.7 kW Single channel (2 Ω load, 1kHz, THD+N=10%), Residual Noise: 290μV, IHF-A weighted, AES-17 filter Distortion: 0.07% THD+N @ 600W, 2Ω Efficiency: 97% @ 1.7 kW, 2Ω Multiple Protection Features: Output Over-current protection (OCP), high side and low side Input Over-voltage protection (OVP), Input Under-voltage protection (UVP), Output DC-offset protection (DCP), Over-temperature protection (OTP) PWM Modulator: Self-oscillating half-bridge topology with optional clock synchronization 参考设计应用: Pro-Audio amplifiers Powered speakers Active Sub-woofers P.A. Systems Car audio amplifier Musical Instrument Amplifier 图3.1.7kW音频功率放大器参考设计外形图 图4.1.7kW音频功率放大器参考设计功能框图 图5.1.7kW音频功率放大器参考设计保护电路功能框图 图6.1.7kW音频功率放大器参考设计主板电路图 图7.1.7kW音频功率放大器参考设计主板输入/输出保护电路图 图8.1.7kW音频功率放大器参考设计主板电路图:Vaa,Vss和Vcc电源DC/DC转换器 图9.IRAUDAMP9子板电路图 IRAUDAMP9主板材料清单(BOM): IRAUDAMP9子板材料清单(BOM): IRAUDAMP9机械材料清单: 图10.IRAUDAMP9主板PCB布局图(顶层) 图11.IRAUDAMP9主板PCB布局图(底层) 图12.IRAUDAMP9子板PCB布局图(顶层) 图13.IRAUDAMP9子板PCB布局图(底层) 详情请见: 和 来源:网络 |
