查看: 728|回复: 0
[供应] IIOT-IPQ6010 support mesh: Form a more powerful network - faster connections
发表于 2024-1-10 13:49:39 | 显示全部楼层 |阅读模式
关键词: mesh
Mesh network is a new type of wireless network topology, which can connect multiple WiFi routers together to form a network with wider coverage and more stable signal. Compared to traditional single router networks, Mesh networks have the following advantages:
1. Wider coverage: Mesh networks can connect multiple routers together to form a wider coverage network, which can cover a larger area, so that you can enjoy a stable network signal in any corner of your home.
2. More stable signal: Mesh network can automatically optimize the signal transmission path to avoid signal interference and congestion, so as to provide a more stable network signal, so that your network connection is smoother.
3. Higher network speed: Mesh networks can connect multiple routers together to form a more powerful network, which provides higher network speeds, allowing you to download and upload files faster, watch high-definition videos, and more.
In short, Mesh networks are a more advanced and intelligent wireless network topology that can provide you with a more stable and faster network connection.
When using the IPQ6010 chip to build a router that supports Mesh functionality, the following features can be achieved:
Multi-node coverage: Mesh networks allow multiple router nodes to be connected together to form a network with wider coverage. Each node can extend network coverage, enabling signals to reach areas that would otherwise not be covered.
Automatic network optimization: The Mesh network can automatically optimize the signal transmission path to avoid signal interference and congestion. When the signal of one node is weak or congested, other nodes can automatically take over and provide a more stable signal, ensuring the stability and quality of the network connection.
Seamless roaming: Mesh networks support seamless roaming, meaning that when you move around your home, the device can automatically switch to the strongest signal node without having to manually reconnect. This means you can maintain a stable Internet connection anywhere in your home without worrying about signal interruptions or delays.
Network Scalability: Mesh networks can scale as needed, and you can add more nodes based on the size and needs of your home or office. This gives the network the flexibility to adapt to different environments and provide better coverage and performance.
In summary, routers based on IPQ6010 chips support Mesh capabilities, which can provide benefits such as wider coverage, more stable signal, automatic network optimization, and seamless roaming. These features make Mesh networks an ideal wireless network solution for modern homes and offices.
Wallys software technology advantages:
Wallys has 10 years of experience in software development and is very experienced in uboot, Linux, wifi protocol, wifi performance, OS and other systems. It mainly uses Qualcomm chips to develop important software such as drivers and kernels, and has the ability to modify and compile to meet customers' different wifi functional requirements. Meanwhile, it participates in openwrt organization and code development. wifi5 product DR40x9 has been officially supported by openwrt.
Hardware technology advantages:
We have a strong hardware design team, and experienced people know that the most difficult part of hardware design is RF circuit design, baseband, etc., while wallys team made 0 error to achieve signal integrity, such as frequency conversion of network card, from 2.4G to 900M, which is a technological breakthrough.
Clients: TIP,Facebook, Openwrt, etc
Email:sales@wallystech.com
WEB:https://www.wallystech.com/
