LT6711GX|HDMI转DP方案最高支持8K
发布时间:2023-4-1 10:47
发布者:WX18312533639
龙迅LT6711GX , HDMI转DP
LT6711GX --- Product Brief HDMI2.1 to DP1.4a with Type-C 1. Features HDMI2.1 Receiver Compliant with HDMI2.1, HDMI2.0b, HDMI1.4 and DVI1.0 Data rate up to 10Gbps Support HDCP 1.4/2.3 Support HDCP repeater Support RGB 8/10/12 bpc, YCbCr4:4:4/ YCbCr4:2:2/ YCbCr4:2:0 /8/10/12 bpc Support up to 8K@30Hz RGB/YCbCr4:4:4/ YCbCr4:2:2 8bpc or YCbCr4:2:0 12 bpc Support up to 4K@120Hz RGB/YCbCr4:4:4/ YCbCr4:2:2 8bpc or YCbCr4:2:0 12 bpc Support up to 8K@60Hz DSC pass-through Support static HDR10 Support FEC Support CEC Support VRR Integrated EDID shadow (max 512-byte) Support ARC DP1.4a/eDP1.5 Transmitter Compliant with DisplayPort specification 1.4a for 1.62Gbps, 2.7Gbps, 5.4Gbps, 8.1Gbps Compliant Embedded DisplayPort specification version 1.5 Support DisplayPort 1/2/4 lanes Support HDCP 1.3/2.3 Support HDCP repeater Support RGB 6/8/10/12 bpc, YCbCr4:4:4/YCbCr4:2:2/ YCbCr4:2:0 8/10/12 bpc Support up to 8K@30Hz RGB 6bpc, YCbCr4:2:2 10 bpc or YCbCr4:2:0 12 bpc Support up to 4K@120Hz RGB 6bpc, YCbCr4:2:2 10 bpc or YCbCr4:2:0 12 bpc Support up to 8K@60Hz DSC pass-through 可以提供完整的设计资料及FAE技术支持 |
