MT7915/IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/IPQ5018/IPQ8072/IPQ8072A/IPQ8074/IPQ8074A/QCN6024/QCN9074/QCN9072/QCN9024/IPQ4018/IPQ4028/AR9223/QCA9880/QCA9882/AR9582/AR9531/AR9344 /AR9342/AX200NGW/QCA9531. Wallys' products It is also constantly upgraded, from WIFI5 to WIFI6, the chipset is also from IPQ4019 to IPQ8074 and so on, Wallys is always the most cutting-edge wireless technology of the times! This section describes three Wallys RouterBoards based on Qualcomm IPQ6010/IPQ6018 chips. DR6018, DR6018C, V01, DR6018S. Let's talk a little bit about the parameters. DR6018 and DR6018C V01, support UECTEL RM500Q-GL&Support: QCN9074 WiFi 6 e card, 802.11ax, IPQ6010, support 2.4g&5g OpenWRT 2×2. The difference is that DR6018 does not have SFP and DR6018C V01 has SFP. Compared with the previous two Routerboards, DR6018S has fewer network ports and no SFP. Therefore, DR6018S cannot be used with a moudle. DR6018 QCN9074 WiFi 6E Card OpenWRT, IPQ6010,802.11ax, 2×2 2.4G&5G 2.5Gbps Ethernet Port Support OpenWRT Support UECTEL RM500Q-GL&Support: Qualcomm-Atheros IPQ6010 Quad-core ARM 64bit A53 @1.8GHz Processor 1GB DDRL3L System Memory 32MB NOR Flash, 256MB NAND Flash Supports Dynamic Frequency Selection (DFS) 2×2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate 2×2 On-board 5GHz radio, up to 1201Mbps physical Data Rate Support: QUECTEL RM500Q-GL Support: QCN9074 WiFi 6E Card Support UECTEL RM500Q-GL&Support CN9074 WiFi 6E Card,802.11ax,IPQ6010 DR6018C V01 Support UECTEL RM500Q-GL&Support CN9074 WiFi 6E Card,802.11ax,IPQ6010 Support OpenWRT 2×2 2.4G&5G 2.5Gbps Ethernet Port SFP Qualcomm-Atheros IPQ6010 Quad-core ARM 64bit A53 @1.8GHz Processor 1GB DDRL3L System Memory 32MB NOR Flash, 256MB NAND Flash Supports Dynamic Frequency Selection (DFS) 2×2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate 2×2 On-board 5GHz radio, up to 1201Mbps physical Data Rate Support: QUECTEL RM500Q-GL Support: QCN9074 WiFi 6E Card DR6018-S Support OpenWRT 2×2 2.4G&5G DR6018-S V02 IPQ6010/IPQ6018/IPQ6000 Quad-core ARM 64bit A53 @1.8GHz Processor 1GB DDRL3L System Memory 8MB NOR Flash, 256MB NAND Flash Supports Dynamic Frequency Selection (DFS) 2×2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate 2×2 On-board 5GHz radio, up to 1201Mbps physical Data Rate QCN9074/QCN9024/QCN6024 series moudle Support 2.4G/5G/6G, single frequency.
