查看: 1168|回复: 0
[供应] DR6018C V01 wifi6 Qualcomm IPQ6010 IPQ6018 openwrt 802.11ax QCN9074/QCN9024
发表于 2022-8-24 11:44:12 | 显示全部楼层 |阅读模式
关键词: IPQ6010 , IPQ6018
MT7915/MT7975/IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/IPQ4018/IPQ4028/IPQ8072/IPQ8072A/IPQ8074/IPQ8074A/IQCN6024/QCN9074/QCN9072/QCN9024/IPQ5018/AR9223/QCA9880/QCA9882/AR9582/AR9531/AR9344 /AR9342/AX200NGW/QCA9531
Enhanced security operations such as physical security and surveillance analytics are required by almost all industries, including banking, retail, critical infrastructure, government, corporate, education and public transportation. Such security measures provide real-time intelligence for live detection of safety and security events and are instrumental not only in safeguarding business intelligence but also in facilitating efficient workforce management and optimizing operational decisions.
EMAIL:sales@wallystech.com
WEB:https://www.wallystech.com/
Qualcomm-Atheros IPQ6010
Quad-core ARM 64bit A53 @1.8GHz Processor
1GB DDRL3L System Memory
32MB NOR Flash, 256MB NAND Flash
Supports Dynamic Frequency Selection (DFS)
2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate
2x2 On-board 5GHz radio, up to 1201Mbps physical Data Rate
Support: QUECTEL RM500Q-GL
Support: QCN9074 WiFi 6E Card
    Absolute Maximum Rating
    Parameter
    Rating
    Unit
    Supply Voltage
    24V~48
    V
    Operating Temperature Range
    -40 to +70
    oC
    Storage Temperature Range
    -45 to +105
    oC
    Operating Humidity Range
    5 to +95 (non-condensing)
    Hardware Specifications
    Symbol
    Parameter
    CPU
    CPU Frequency
    Quad-core ARM 64 bit A53 @1.8 GHz processor
    System Memory
    1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
    Ethernet Port
    1 x 1Gbps Ethernet Ports & POE3 x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
    SFP Port1x SFP port
    NGFF Slot
    M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0
    SD Card Slot
    1x SD Card Slot
    USB /header
    1x USB 2.0 Port
    POE
    24V~48V passive POE/Active POE(Suport 802.3bt)
    DC Jack
    24V power supply
    LED header
    FFC/FPC Connector
    Serial Port
    1x Serial Port 4 Pin Connector
    Wireless
    On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
    On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
    4 x MMCX Connectors
    BluetoothCSR8811 BLE 4.2
    Nor Flash
    32MB
    Nand Flash
    256MB
    DDR
    256MB~512MB
    Dimension
    185mm x 116mm
    Radio TX Specifications(5180MHz-5825MHz)
    Operating Mode
    Data Rate
    Power
    Tolerance
    1 Chain
    2 Chains
    5Ghz 802.11ax HE20
    MCS0
    20dBm
    23dbm
    ±2dB
    MCS1
    20dBm
    23dBm
    ±2dB
    MCS2
    20dBm
    23dBm
    ±2dB
    MCS3
    20dBm
    23dBm
    ±2dB
    MCS4
    19dBm
    22dBm
    ±2dB
    MCS5
    18dBm
    21dBm
    ±2dB
    MCS6
    17dBm
    20dBm
    ±2dB
    MCS7
    16dBm
    19dBm
    ±2dB
    MCS8
    15dBm
    18dBm
    ±2dB
    MCS9
    14dBm
    17dBm
    ±2dB
    MCS10
    13dBm
    16dBm
    ±2dB
    MCS11
    13dBm
    16dbm
    ±2dB
    5Ghz 802.11ax HE400
    MCS0
    20dBm
    23dbm
    ±2dB
    MCS1
    20dBm
    23dBm
    ±2dB
    MCS2
    20dBm
    23dBm
    ±2dB
    MCS3
    20dBm
    23dBm
    ±2dB
    MCS4
    19dBm
    22dBm
    ±2dB
    MCS5
    18dBm
    21dBm
    ±2dB
    MCS6
    17dBm
    20dBm
    ±2dB
    MCS7
    16dBm
    19dBm
    ±2dB
    MCS8
    15dBm
    18dBm
    ±2dB
    MCS9
    14dBm
    17dBm
    ±2dB
    MCS10
    13dBm
    16dBm
    ±2dB
    MCS11
    13dBm
    16dbm
    ±2dB
    5Ghz 802.11ax HE80
    MCS0
    20dBm
    23dbm
    ±2dB
    MCS1
    20dBm
    23dBm
    ±2dB
    MCS2
    20dBm
    23dBm
    ±2dB
    MCS3
    20dBm
    23dBm
    ±2dB
    MCS4
    19dBm
    22dBm
    ±2dB
    MCS5
    18dBm
    21dBm
    ±2dB
    MCS6
    17dBm
    20dBm
    ±2dB
    MCS7
    16dBm
    19dBm
    ±2dB
    MCS8
    15dBm
    18dBm
    ±2dB
    MCS9
    14dBm
    17dBm
    ±2dB
    MCS10
    13dBm
    16dBm
    ±2dB
    MCS11
    13dBm
    16dbm
    ±2dB
