MT7915+MT7975 support linux 4.4 support 2.4G 5G at same time WEB:https://www.wallystech.com/ MT7915+MT7975 Chipset 2.4GHz max 23dBm & 5GHz max 35dBm output power IEEE 802.11ac / ax compliant & backward compatible with 802.11ax/ac/a/b/g/n 2×2 2.4G & 2×2 5G MIMO Technology, up to 1.8Gbps Mini PCI Express edge connector SupporttheFrequency2412MHz~2482MHz SupporttheFrequency5180MHz~5825MHz RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals Supports Spatial Multiplexing,Cyclic-Delay Diversity (CDD), Low-Density Parity Check (LDPC) Codes,Maximal Ratio Combining (MRC), Space Time Block Code (STBC) Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards Supports Dynamic Frequency Selection (DFS) CardsareindividuallycalibratedforQualityAssurance
