查看: 1662|回复: 0
[供应] network card wifi5 wifi6 MT7915 MT7975 QCN9074 QCN9072 QCN9024 QCA9880 QCA9882
发表于 2022-8-11 17:42:47 | 显示全部楼层 |阅读模式
关键词: MT7915 , MT7975 , QCN9074 , QCN9072 , QCN9024
wallys//network card MT7915 MT7975 QCN9074 QCN9072 QCN9024  QCA9880 QCA9882
DR900VX/DR600VX
QCA9880 2x2 2.4G/5G FCC/CE/IC
Qualcomm-Atheros QCA9880 chipset
2.4GHz max 26dBm & 5GHz max 25dBm output power
IEEE 802.11ac compliant & backward compatible with 802.11a/b/g/n
3x3 MIMO Technology, up to 1.3Gbps
Mini PCI Express edge connector
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Supports Spatial Multiplexing, Cyclic-Delay Diversity (CDD), Low-Density Parity Check (LDPC) Codes, Maximal Ratio
Combining (MRC), Space Time Block Code (STBC)
Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards
Supports Dynamic Frequency Selection (DFS)
FCC,CE and IC Certification
DR882
802.11AC 802.11AN wifi QCA9882
2x 2 5G High power Radio card
Featuring with industrial-grade Atheros’s QCA9882 chipset
Integrated with 2x 2 5G high power Radio Card
4.940GHz to 5.825GHz Frequency Range
2 x 5G MMCX Connectors
20MHz/40MHz/80MHz Bandwidth
Support 802. 11AC/AN
DR7915
WiFi6 MiniPCIe Module 2T2R
2×2.4GHz 2x5GHz MT7915 MT7975
MT7915+MT7975 Chipset
2.4GHz max 23dBm & 5GHz max 35dBm output power
IEEE 802.11ac / ax compliant & backward compatible with 802.11ax/ac/a/b/g/n
2×2 2.4G & 2×2 5G  MIMO Technology, up to 1.8Gbps Mini PCI Express edge connector
SupporttheFrequency2412MHz~2482MHz
SupporttheFrequency5180MHz~5825MHz
Supports Spatial Multiplexing,Cyclic-Delay Diversity (CDD), Low-Density Parity Check  (LDPC) Codes,Maximal Ratio Combining (MRC), Space Time Block Code (STBC)
CardsareindividuallycalibratedforQualityAssurance
Wallys has been specializing in product design & manufacturing and delivering superior OEM/ODM services in wireless communications. Dedicated to innovative designs for wireless modules. Customization is also supported, We have 90% of the world market, We're a supplier to Facebook.
EMAIL:sales@wallystech.com
WEB:https://www.wallystech.com/
