查看: 7044|回复: 0
VB.NET下采用索引对WinIO的封装类(WinIO.vb)
发表于 2009-4-3 00:15:09 | 显示全部楼层 |阅读模式
关键词: NET , WinIO , 封装 , 索引
Imports System.Runtime.InteropServices
Imports System.Text
Imports System.Threading
Imports System.Windows.Forms 'MessageBox需要
'菜农HotPower@126.com 2008.11.13 于雁塔菜地
Public Class WinIO
#Region "WinIO API"
    Private Shared Function InitializeWinIo() As Boolean
    End Function
    Private Shared Function ShutdownWinIo() As Boolean
    End Function
    Private Shared Function GetPortVal( _
        ByVal PortAddr As UInt16, ByRef PortVal As UInt32, ByVal bSize As Byte) As Boolean
    End Function
    Private Shared Function SetPortVal( _
        ByVal PortAddr As UInt16, ByVal PortVal As UInt32, ByVal bSize As Byte) As Boolean
    End Function
#End Region
    '在Form1.cs内加Private WinIoPort As New WinIO()
    Private blEnable As Boolean
    Private blError As Boolean
    Sub New() '//构造函数(自动运行)
        blEnable = False
        blError = False
        Try
            blEnable = InitializeWinIo() '加载WinIO
        Catch ex As System.Exception
            MessageBox.Show(ex.Message, "系统提示", MessageBoxButtons.OK, MessageBoxIcon.Error)
        End Try
    End Sub
    Protected Overrides Sub Finalize() '析构函数(自动运行)
        If blEnable = True Then
            ShutdownWinIo() '卸载WinIO
        End If
    End Sub
    Public ReadOnly Property Err() As Boolean
        Get
            Return blError
        End Get
    End Property
    Public ReadOnly Property Enable() As Boolean
        Get
            Return blEnable
        End Get
    End Property
    Default Public Property My(ByVal Index As UInt16) As Byte
        'x = WinIoPort(&H378)
        Get
            Dim val As UInt32
            blError = GetPortVal(Index, val, 1)
            Return (val And &HFF)
        End Get
        'WinIoPort(&H378) = &H55
        Set(ByVal value As Byte)
            blError = SetPortVal(Index, value, 1)
        End Set
    End Property
    Default Public Property My(ByVal Index As UInt16, ByVal size As Byte) As UInt32
        'x = WinIoPort(&H378, 1) x = WinIoPort(&H378, 2) x = WinIoPort(&H378, 4)
        Get
            Dim val As UInt32
            blError = GetPortVal(Index, val, size)
            Return val
        End Get
        'WinIoPort(&H378, 1) = &H55 WinIoPort(&H378, 2) = &H5555
        'WinIoPort(&H378, 4) = &H12345678
        Set(ByVal value As UInt32)
            blError = SetPortVal(Index, value, size)
        End Set
    End Property
End Class
