Atmel MSL4164 LED电视机直接背光解决方案
发布时间:2011-6-29 15:41
发布者:Liming
Atmel公司MSL4163/MSL4164是电视机直接背光LED驱动器.MSL4164具有20MHz SPI总线,每串LED的电流为100mA,电流精度和匹配度优于3%,可驱动16x10个白光LED,16个器件级联可驱动高达2560个白光LED.而MSL4163提供1MHz I2C串口.器件包括先进的PWM引擎,以及片上EEPROM等,主要用在电视和台式电脑监视器,医疗和工业仪表,汽车音/视频显示器.本文介绍了MSL4163/MSL4164主要特性,方框图和典型应用电路,级联连接电路. The Atmel mSilica MSL4164 compact, high-power LED string driver uses internal current control MOSFETs to sink up to 100mA per string, with current accuracy and matching better than 3%. The MSL4164 drive 16 parallel strings of 10 white LEDs each, for a total of 160 white LEDs per device. Sixteen interconnected devices control up to 2560 white LEDs. The MSL4164 features a 20MHz SPI bus, and the MSL4163 offers a 1MHz I2C serial interface. Both interfaces support video frame-by-frame LED string intensity control for up to 16 interconnected devices to allow active area dimming. The devices include an advanced PWM engine that easily synchronizes to a video signal, and per-string phase adjustment to reduce unwanted LCD artifacts such as motion blur. Additionally, an on-chip EEPROM allows the power-up defaults to be customized through the serial interface. The MSL4163/4 adaptively control the DC-DC converters that power the LED strings, using Atmel’s Adaptive SourcePower™ technology. These efficiency optimizers minimize power use, while maintaining LED current accuracy. A unique combination of peak current controls and pulse width management offer simple, full- screen brightness control, versatile area dimming, and a consistent white point. One external resistor sets the global peak reference current for all LED strings, and global peak current fine-tuning is available through an 8-bit register. Global string drive pulse width is adjusted with an 8-bit global intensity register, and individual string pulse width is modulated with 12-bit registers. The MSL4163/4 feature fault monitoring of open circuit, short circuit, loss of video sync, and over-temperature conditions, and provide a fault output to notify the system controller. Detailed fault status and control are available through the serial interface. The MSL4163/4 are offered in 6 x 6 x 0.75mm, 40-pin TQFN packages and operate over a -40℃ to 85℃ temperature range. MSL4163/MSL4164主要特性: • 12-bit PWM String Dimming Operates at 240Hz • Fast Serial Interfaces Support up to 16 Devices per Bus: - MSL4164: 20MHz SPI - MSL4163: 1MHz I2C • 8-bit Adaptive Power Correction Maximizes Efficiency of up to Three String Power Supplies • Drives 16 Parallel LED Strings of 10 White LEDs Each, for up to 2560 White LEDs per Serial Bus • Supports Adaptive, Real-time Area Dimming for Highest Dynamic Range LCD TVs and Monitors • Programmable String Phase Reduces Motion Blur • Global Intensity Control via Serial Interface • 100mA Peak, 60mA Average LED String Current • Single Resistor Sets Peak Current for all LED Strings • ±3% Current Accuracy and Current Balance • Video Frame (Vsync) and Line (Hsync) Sync Inputs • Sync Loss Detectors Optionally Disable LED Strings • Multiple MSL4163/4s Share String Power Supplies and Automatically Negotiate the Optimum Supply Voltage • EEPROM Allows Customized Power-on Defaults • Less than 1μa LED String-off Leakage Current • String Open Circuit and LED Short Circuit Detection with Adjustable Short Circuit Threshold • Individual Fault Detection Enable for Each String • Over-temperature Shutoff Protection • -40℃ To +85℃ Operating Temperature Range • 4kv HBM ESD Rated String Drive Outputs MSL4163/MSL4164应用: Long Life, Efficient LED Backlighting for: • Televisions and Desktop Monitors • Medical and Industrial Instrumentation • Automotive Audio-visual Displays 图1.MSL4163/MSL4164方框图 图2.MSL4163/MSL4164应用电路 图3.MSL4164驱动16串160个白光LED(每串60mA)应用电路 图4.多MSL4163/MSL4164级联连接电路 详情请见: http://www.atmel.com/dyn/resources/prod_documents/F1_MSL4163_64_DB.pdf |
