了解线性电源规格
发布时间:2013-4-2 12:40    发布者:eechina
关键词: 线性电源
At first glance, a variable DC power supply appears to be a fairly simple device. However, it is a sophisticated, accurate,electrically-rugged workhorse. It must reliably deliver voltage and current that is stable, precise, and clean, no matter its load—resistive, inductive, capacitive, low impedance, high impedance, steady-state, or variable. How well the power supply fulfills this mission and where it reaches its limits are defined in its specifications. Choosing the right power supply for your application requires a good understanding of power supply specifications.
下载: Ser2200LinPwrSuppySpecsAppNote.pdf (620.46 KB)
本文地址:https://www.eechina.com/thread-112969-1-1.html     【打印本页】
rinllow6 发表于 2013-4-2 13:30:22
谢谢!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
