安森美LED驱动方案
发布时间:2012-11-18 00:38
发布者:1770309616
LED在光输出、能效及成本方面得到了全面改善,同时具备了小巧、低压工作及环保等众多优势,应用范围也在不断拓宽。未来,LED照明在通用照明、LCD背光、汽车照明等领域的增长前景尤为可观。安森美半导体提供丰富的LED驱动器产品,可满足各种LED照明应用需求。 主要特性: _Integrated 1.5 A Switch _Input Voltage Range from 3.0 V to 40 V _Low Feedback Voltage of 235 m V _Cycle -by-Cycle Current Limit _No Control Loop Compensation Required _Frequency of Operation Adjustable up to 250 kHz _Operation with All Ceramic Output Capacitors or No Output Capacitance _Analog and Digital PWM Dimming Capability _Internal Therma l Shutdown with Hysteresis _Automotive Version Available 主要应用: _Automotive and Marine Lighting _High Power LED Driver _Constant Current Source _Low Voltage LED Lighting 方案特性: LEDs are replacing traditional incandescent and halogen lighting sources in architectural, industrial, residential and the transportation lighting. The key challenge in powering LED’s is providing a constant current source. The evaluation board for the NCP3065/NCV3065 can be easily configured for a variety of constant current buck and boost LED driver applications. It describes a DC−DC converter circuits that can easily be configured to drive LEDs at several different output currents and can be configured for either AC or DC input. The NCP3065/NCV3065 can be configured in a several driver topologies to a drive string of LEDs: be it traditional low power LEDs or high brightness high power LEDs such as the Lumileds Luxeonâ K2 and Rebel series, the CREE XLAMPâ 4550 or XR series, the OSRAM OSTARâ, TopLEDâ and Golden Dragonâ. 方案原理图: 参照PCB图: 详情请见: (网络) |
