低电压大电流,高效率升压芯片-ZCC2007兼容SY7066
发布时间:2025-4-25 17:44    发布者:四维电子
关键词: 兼容SY7066
Description
The ZCC2007 is a high efficiency, current mode, fully integrated boost converter, which can start up from an input voltage as low as 1.8V and convert up to 5.5V output voltage. During shutdown, it can disconnect the output from the input.
The converter integrates 10mΩ/30mΩpower MOSFETs and can deliver up to 3A output current at 5V output with 2.5V input supply. When the output is shorted, theZCC2007 enters
hiccup protection mode and recovers
automatically when the output short is removed. The ZCC2007 also includes input under voltage lockout, output over voltage protection, cycle-by- cycle over current protection,short circuit protection and thermal shutdown to prevent damage in the event of output overload.The ZcC2007 is available in a low profile 10-pin2mmx2mm FCQFN package.
Features
1.8V Minimum Input Voltage
Output Voltage Range:2.5V to 5.5V8A Peak Switching Current Limit
10mΩ(LS)/ 30mΩ(HS) Power MOSFETs High Efficiency(96.2% at VIN= 3.7V,VouT =5V,lout=3A)
True Load Disconnection from Input±1% Accurate Reference Voltage
Internal Compensation and Soft Start Low Shutdown Current <1μA
Over-Current and Short-Circuit Protection Output Overvoltage Protection Thermal Shutdown
2x2mm FCQFN 10-Pin Package This is a Pb-Free Device
本文地址:https://www.eechina.com/thread-886468-1-1.html     【打印本页】
  • 初学者在电源电路设计中常犯的错误(以及如何避免)
