PS5050是一款高性能的高侧 OR-ing FET 控制器替代LM5050
发布时间:2025-4-15 17:23    发布者:百盛
产品概述 PS5050-1 是一款高性能的高侧 OR-ing FET 控制器,适用于冗余电源系统。它通过
外部 N 沟道 MOSFET 实现理想的二极管整流功能,可显著降低传统二极管整流器带来的功率损耗和电压
降。PS5050-1 提供了快速的电流反转响应能力,能够在 50ns 内关闭 MOSFET,确保系统的稳定性和可
靠性。
PS5050-1 is a high-performance high side OR ing FET controller,suitable for redundant power systems.
It achieves ideal diode rectification function through external N-channel MOSFET, which can significantly
reduce the power loss and voltage drop caused by traditional diode rectifiers. PS5050-1 provides fast
current reversal response capability, capable of turning off MOSFETs within 50ns, ensuring system stability
and reliability.
特性
提供标准版和 AEC-Q100 认证版本(PS5050Q0MK-1 最高结温可达 150°C,PS5050Q1MK-1 最高
结温可达 125°C)。Provide standard and AEC-Q100 certified versions (PS5050Q0MK-1 has a maximum junction
temperature of 150 ° C, PS5050Q1MK-1 has a maximum junction temperature of 125 ° C).
宽输入电压范围:VIN 1V 75V(VIN < 5V 时需额外提供 VBIAS)。Wide input voltage range: VIN
is 1V to 75V (VBIAS is required when VIN<5V).
● 100V 瞬态耐受能力。 100V transient withstand capability.
内置电荷泵驱动外部 N 沟道 MOSFET Built in charge pump drives external N-channel MOSFET
快速响应:在电流反转时,响应时间仅为 50ns。Fast response: When the current reverses, the response time
is only 50ns.
● 2A 峰值栅极关断电流。2A peak gate turn off current.
最小 VDS 钳位,实现更快的关断速度。Minimum VDS clamp for faster shutdown speed.
封装类型:SOT-6(薄型 SOT-23-6)。Packaging type: SOT-6 (thin SOT-23-6).
应用领域
冗余电源(N+1)的主动 OR-ing Active OR ing of redundant power supply (N+1).
本文地址:https://www.eechina.com/thread-885758-1-1.html     【打印本页】
