ADI ADSP-BF609 Blackfin处理器低成本评估方案
发布时间:2012-3-29 10:59
发布者:1770309616
ADI公司的ADSP-BF609 Blackfin处理器采用ADI/Intel微信号架构(MSA),具有正交RISC类微处理器指令集,单指令多数据(SIMD)多媒体功能,处理器工作频率高达500 MHz,静态功耗低,主要用在汽车电子,嵌入式工业控制,马达控制,仪器仪表等.ADI公司的ADSP-BF609 EZ-KIT Lite® 评估系统和CrossCore® Embedded Studio (CCES)开发工具连接,用来评估ADSP-BF60x Blackfin处理器的功能.本文介绍了ADSP-BF609 主要特性,方框图,Blackfin 处理器核框图,ADSP-BF609 EZ-KIT Lite® 评估板主要特性,方框图,电路图和材料清单. ADSP-BF609 Evaluation Hardware for the ADSP-BF60x Blackfin Processor Family The ADSP-BF609 processor is a member of the Blackfin family of products, incorporating the Analog Devices/Intel Micro Signal Architecture (MSA). Blackfin processors combine a dual-MAC state-of-the-art signal processing engine, the advantages of a clean, orthogonal RISC-like microprocessor instruction set, and single-instruction, multiple-data (SIMD) multimedia capabilities into a single instruction-set architecture. The processor offers performance up to 500 MHz, as well as low static power consumption. Produced with a low-power and low voltage design methodology, they provide world-class power management and performance. By integrating a rich set of industry-leading system peripherals and memory , Blackfin processors are the platform of choice for next-generation applications that require RISC-like programmability, multimedia support, and leadingedge signal processing in one integrated package. These applications span a wide array of markets, from automotive systems to embedded industrial, instrumentation and power/motor control Applications. ADSP-BF609 主要特性: Dual-core symmetric high-performance Blackfin processor, up to 500 MHz per core Each core contains two 16-bit MACs, two 40-bit ALUs, and a 40-bit barrel shifter RISC-like register and instruction model for ease of programming and compiler-friendly support Advanced debug, trace, and performance monitoring Pipelined Vision Processor provides hardware to process signal and image algorithms used for pre- and co-processing of video frames in ADAS or other video processing applications Accepts a range of supply voltages for I/O operation. Off-chip voltage regulator interface 349-ball (19 mm × 19 mm) RoHS compliant BGA package 存储器特性: Each core contains 148K bytes of L1 SRAM memory (processor core-accessible) with multi-parity bit protection Up to 256K bytes of L2 SRAM memory with ECC protection Dynamic memory controller provides 16-bit interface to a single bank of DDR2 or LPDDR DRAM devices Static memory controller with asynchronous memory interface that supports 8-bit and 16-bit memories Flexible booting options from flash, eMMC and SPI memories and from SPI, link port and UART hosts Memory management unit provides memory protection ![]() 图1.ADSP-BF609方框图 ![]() 图2.ADSP-BF609 Blackfin处理器核方框图 ADSP-BF609 EZ-KIT Lite® 评估系统 The ADSP-BF609 EZ-KIT Lite® is a low-cost evaluation system for the ADSP-BF60x Blackfin® processors. The evaluation board is designed to be used in conjunction with the CrossCore® Embedded Studio (CCES) development tools to test capabilities of the ADSP-BF60x Blackfin processors. The CCES development environment aids advanced application code development and debug, such as: • Create, compile, assemble, and link application programs written in C++, C, and assembly • Load, run, step, halt, and set breakpoints in application programs • Read and write data and program memory • Read and write core and peripheral registers • Plot memory Access to the processor from a personal computer (PC) is achieved through a USB port (when a debug agent is mounted on the EZ-KIT Lite board) or an external JTAG emulator. The USB interface provides unrestricted access to the ADSP-BF609 processor and evaluation board peripherals. Analog Devices JTAG emulators offer faster communication between the host PC and target hardware. ![]() 图3.ADSP-BF609 EZ-KIT Lite® 评估板外形图 ADSP-BF609 EZ-KIT Lite® 评估板主要特性: • Analog Devices ADSP-BF609 Blackfin processor • 349-pin LFBGA package • 25 MHz CLKIN oscillator • 48 MHz USB CLKIN • Double Data Rate Synchronous Dynamic Random-Access Memory (DDR2 SDRAM) • Micron MT47H64M16HR-3 • 64M x 16 bit (1 Gb) • Burst flash memory • Micron PC28F128P33T85B • 16M x 16-bit (32 MB) flash memory • Quad Serial Peripheral Interface (SPI) • Winbond W25Q32 • 32 Mb serial flash memory • Ethernet PHY • National Semiconductor • DP83848C 10/100 PHY • Two LEDs integrated into the RJ-45 connector:link/activity • Universal Asynchronous Receiver/Transmitter (UART) • ADM3315 RS-232 line driver/receiver • DB9 female connector • Temp sensor • On Semiconductor • ADM1032 two-wire sensor • Controller Area Network (CAN) • NXP TJA1041 • RJ-11 connector • Debug interface • JTAG header for use with ADI emulators • Standalone debug agent • LEDs • Eight LEDs: one power (green), one board reset (red), one temperature limit (amber), Ethernet speed (green), and four general-purpose (amber) • Push buttons • Four push buttons: one reset, one wake, and two IRQ/flag • Expansion Interface 3 (EI3) • Next generation of the expansion interface design, provides access to most of the processor signals • Power supply • CE approved • 5V @ 3.6 Amps • Other features • Link port connectors • SD/MMC memory connector • Rotary encoder • MP JTAG in and out connectors • 0.05-ohm resistors for processor current measurement • JTAG ICE 14-pin header • USB cable Traditional mechanical switches for changing the board’s factory setup have been removed in favor of I2C controlled software switches. The only remaining mechanical switches are the JTAG switches, boot mode switch, and push buttons. The JTAG switches are provided for setting up single-processor JTAG communications or multiple-processor Configurations. ADSP-BF609 EZ-KIT Lite® 评估系统包括: ADSP-BF609 EZ-KIT Lite package contains the following items. • ADSP-BF609 EZ-KIT Lite board • Standalone debug agent (SADA2) • USB cable • 5 in 1 USB cable kit • CE approved power supply • Ethernet cable • 2 GB memory card • 4 nylon standoffs • 4 nylon hex nuts ![]() 图4.ADSP-BF609 EZ-KIT Lite® 评估板方框图 ![]() 图5.ADSP-BF609 EZ-KIT Lite® 评估板电路图(1) ![]() 图6.ADSP-BF609 EZ-KIT Lite® 评估板电路图(2) ![]() 图7.ADSP-BF609 EZ-KIT Lite® 评估板电路图(3) ![]() 图8.ADSP-BF609 EZ-KIT Lite® 评估板电路图(4) ![]() 图9.ADSP-BF609 EZ-KIT Lite® 评估板电路图(5) ![]() 图10.ADSP-BF609 EZ-KIT Lite® 评估板电路图(6) ![]() 图11.ADSP-BF609 EZ-KIT Lite® 评估板电路图(7) ![]() 图12.ADSP-BF609 EZ-KIT Lite® 评估板电路图(8) ![]() 图13.ADSP-BF609 EZ-KIT Lite® 评估板电路图(9) ![]() 图14.ADSP-BF609 EZ-KIT Lite® 评估板电路图(10) ![]() 图15.ADSP-BF609 EZ-KIT Lite® 评估板电路图(11) ![]() 图16.ADSP-BF609 EZ-KIT Lite® 评估板电路图(12) ![]() 图17.ADSP-BF609 EZ-KIT Lite® 评估板电路图(13) ![]() 图18.ADSP-BF609 EZ-KIT Lite® 评估板电路图(14) ![]() 图19.ADSP-BF609 EZ-KIT Lite® 评估板电路图(15) ADSP-BF609 EZ-KIT Lite® 评估板材料清单: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() 详情请见: ![]() ![]() |
