查看: 6935|回复: 4
[提问] RS232状态机Verilog编程问题...
发表于 2012-7-16 16:51:02 | 显示全部楼层 |阅读模式
关键词: fit , verilog , 串口通信
1积分
编译的时候出现
Error: Node "CLK" of type Register cell has no legal location
Error: Can't fit design in device
这两个错误...我用的开发板芯片是EP2C8Q208C...产生这两个错误的原因是什么?是开发平台的设置问题还是我的代码问题?
以下是完整代码
module Test(CLK_50M,REST,DAT,RXEXT,RXD,TXLD,TXD,READY);//READY=11:RX and TX is idle;READY=0x:RX is busy and TX is idle;READY=x0:RX is idle and TX is busy;
input CLK_50M,REST;
inout [7:0] DAT;
input RXEXT,RXD;
input TXLD;
output TXD;
output [1:0] READY;
reg TXD;
reg [7:0] DAT;
reg [1:0] READY;
reg [15:0] CNT;
reg CLK;
reg [2:0] CLKSTATE;
reg [7:0] RXBUFF,TXBUFF;
reg RXBUFF1,RXBUFF2;//异步通信,接收使用两级缓存
reg RXEN,TXEN;
reg [3:0] RXSTATE,TXSTATE;
parameter Start=4'b0000,
    Bit0=4'b0001,Bit1=4'b0010,Bit2=4'b0011,Bit3=4'b0100,Bit4=4'b0101,Bit5=4'b0110,Bit6=4'b0111,Bit7=4'b1000,
    Stop=4'b1001,
    BaudRate8x=16'd324;//9600
always @(posedge CLK_50M or negedge REST)//分频
if(!REST) CNT <= 16'h0000;
else if(CNT!=BaudRate8x) CNT <= CNT+1'b1;
   else CNT <= 16'h0000;
if(!REST) CLK <= 1'b0;
else if(CNT==BaudRate8x) CLK <= ~CLK;
always @(posedge CLK or negedge REST)//记录时隙
if(!REST) CLKSTATE <= 3'b000;
else CLKSTATE <= CLKSTATE+1'b1;
always @(CLKSTATE)//发送使能
if(CLKSTATE==3'b111) TXEN=1;
else TXEN=0;
always @(CLKSTATE)//接收使能
if(CLKSTATE==3'b111) RXEN=1;
else RXEN=0;
always @(posedge CLK)//发送缓冲
if((READY==2'bx1)&&TXLD) TXBUFF <= DAT;
always @(posedge CLK)//接收提取
if((READY==2'b1x)&&RXEXT) DAT <= RXBUFF;
always @(posedge CLK or negedge REST)//发送
if(!REST)begin TXBUFF <= 8'h00;TXSTATE <= 4'h0; end
else if(TXBUFF)
  case(TXSTATE)
   Start:if(TXEN)begin TXD <= 1'b0;TXSTATE <= Bit0;READY[0] <= 1'b0; end
   Bit0:if(TXEN)begin TXD <= TXBUFF[0];TXSTATE <= Bit1; end
   Bit1:if(TXEN)begin TXD <= TXBUFF[1];TXSTATE <= Bit2; end
   Bit2:if(TXEN)begin TXD <= TXBUFF[2];TXSTATE <= Bit3; end
   Bit3:if(TXEN)begin TXD <= TXBUFF[3];TXSTATE <= Bit4; end
   Bit4:if(TXEN)begin TXD <= TXBUFF[4];TXSTATE <= Bit5; end
   Bit5:if(TXEN)begin TXD <= TXBUFF[5];TXSTATE <= Bit6; end
   Bit6:if(TXEN)begin TXD <= TXBUFF[6];TXSTATE <= Bit7; end
   Bit7:if(TXEN)begin TXD <= TXBUFF[7];TXSTATE <= Stop; end
   Stop:if(TXEN)begin TXD <= 1'b1;TXSTATE <= 4'b0000;READY[0] <= 1'b1; end
   default:begin TXSTATE <= 4'b0000;TXBUFF <= 8'h00;READY[0] <= 1'b1; end
  endcase
always @(posedge CLK or negedge REST)//接收
if(!REST)begin RXBUFF <= 8'h00;RXSTATE <= 4'h0; end
else begin
  RXBUFF1 <= RXD;
  RXBUFF2 <= RXBUFF1;
  case(RXSTATE)
   Start:if(!RXD)begin RXSTATE <= Bit0;READY[1] <= 1'b0; end
      else begin RXSTATE <= 4'b0000;READY[1] <= 1'b1; end
   Bit0:if(RXEN)begin RXBUFF[0] <= RXBUFF2;RXSTATE <= Bit1; end
   Bit1:if(RXEN)begin RXBUFF[1] <= RXBUFF2;RXSTATE <= Bit2; end
   Bit2:if(RXEN)begin RXBUFF[2] <= RXBUFF2;RXSTATE <= Bit3; end
   Bit3:if(RXEN)begin RXBUFF[3] <= RXBUFF2;RXSTATE <= Bit4; end
   Bit4:if(RXEN)begin RXBUFF[4] <= RXBUFF2;RXSTATE <= Bit5; end
   Bit5:if(RXEN)begin RXBUFF[5] <= RXBUFF2;RXSTATE <= Bit6; end
   Bit6:if(RXEN)begin RXBUFF[6] <= RXBUFF2;RXSTATE <= Bit7; end
   Bit7:if(RXEN)begin RXBUFF[7] <= RXBUFF2;RXSTATE <= Stop; end
   Stop:if(RXEN&&RXD)begin RXSTATE <= 4'b0000;READY[1] <= 1'b1; end
     else begin RXSTATE <= Bit0;READY[1] <= 1'b0; end
   default:begin RXSTATE <= 4'b0000;RXBUFF <= 8'h00;READY[1] <= 1'b1; end
  endcase
end
endmodule
最佳答案
查看完整内容
时钟要放到时钟引脚上!
发表于 2012-7-16 16:51:03 | 显示全部楼层
时钟要放到时钟引脚上!
发表于 2012-7-17 14:08:47 | 显示全部楼层
时钟信号一定要配置在相对应的管脚上,否则编译过不了。
 楼主| 发表于 2012-7-17 16:40:01 | 显示全部楼层
回复2楼asyou
貌似还真是这样子...新建一个工程不分配引脚就能通过编译了...受教了~
发表于 2012-12-2 08:50:36 | 显示全部楼层
