CS5466|CS5366替代AG9411|typecz转hdmi2.1芯片方案|HDMI 8K转换方案
发布时间:2023-4-20 14:46
发布者:qq2755130042
CS5366替代AG9411,替代LT8711HE,2lane USB-C to HDMI 4k@30Hz + charging (+USB3.0) CS5466 8K30HZ(4K144)by 2lane typec转hdmi 8K转换器方案芯片 CS5363 2lane DP to HDMI 4k@60Hz CS5801AN HDMI TO eDP/DP CS5516AN MIPI/DSI TO LVDS CS5518AN MIPI/DSI TO 双路LVDS CS5262AN DP to HDMI 4k@60Hz + VGA CS5263AN DP to HDMI 4k@60Hz CS5265AN USB-C to HDMI 4k@60Hz CS5266AN USB-C to HDMI 4k@30Hz + charging (+USB3.0) CS5266BN USB-C to HDMI 4k@30Hz + charging (+USB3.0) CS5268AN USB-C to HDMI 4k@30Hz +VGA + charging (+ USB3.0) CS5258AN USB-C to HDMI 4k@30Hz +VGA CS5269AN USB-C to HDMI 4k@60Hz +VGA + charging (No USB3.0) CS5260AN USB-C to VGA CS5261BN USB-C to HDMI 4k@30Hz CS5261CN USB-C to HDMI 4k@30Hz(出厂预置FW,不可更新FW) CS5202AN DP to VGA CS5211AN eDP to LVDS CS5212AN DP to VGA CS5210AN HDMI TO VGA(无音频) CS5203AN HDMI TO VGA(带音频)(无HDCP KEY) CS5213AN HDMI TO VGA(带音频) CS5218AN DP++ to HDMI(4K@30HZ) 未来量产 MST、USB2.0HUB、USB3.0HUB USB音频声卡 SSS1629 USB Audio, 耳麦一体 SSS1530 USB Audio, 耳麦一体,+MCU线控功能 SSS1630 USB Audio SSS1700 USB Audio,, 耳麦一体,线控功能,欧美规切换 USB HUB及读卡器 PL2586 USB2.0 4-port Hub Controller IC CS8.1 USB2.0 4-port Hub Controller IC MA8121 USB 2.0 to SD (Micro SD/MMC) Host Card Reader IC MA8621 Combo Hub (1-SD/MMC reader+3-port Hub) BL8810 USB 2.0 SD/MMC Card Reader Controller Typec扩展坞周边配套电源芯片 TD1583 配套电源方案 TD6810 配套电源方案 TDM3307C 配套电源方案 CS201 USB Audio,16bit48k, 耳麦一体,线控功能,美规 CS202 USB Audio,16bit48k, 耳麦一体,线控功能,欧美规切换 CS302 USB Audio,16bit96k, 耳麦一体,线控功能,欧美规切换 HDMI/USB/PCIE切换器 ASW3642 HDMI切换器ic ASW3810 PICE切换 ASW3410 USB3.0切换 24C64 存储ic VL170 Typec母座翻转协议芯片 VL171 Typec母座翻转协议芯片 |
