IPQ8074 is Qualcomm's first WiFi6 networking solution designed to meet the growing demands of increasingly crowded and dense Wi-Fi environments. It offers the best configuration to bring unprecedented capacity and coverage to Wi-Fi networks and supports several unique features to ensure the best Wi-Fi performance for all types of applications. IPQ8074A compared with IPQ8074, IPQ8074A has added the MU-MIMO Uplink, OFDMA-UL, MU-RTS (Multi-User Request To Send), Preamble Finally, Spatial Reuse (OBSS PD). Maximizing the payload data rate by improving efficiency reduces contention between STAs and improves channel utilization. This shows that IPQ8074A can have more stable and higher wireless data rate, anti-interference ability is also more excellent. DR8074A(HK01)Features■ Qualcomm Atheros IPQ8074A AR Quad Core CPU ■ On-board 5GHz radio, up to 4804Mbps physical data rate 32MB NOR Flash, 256MB NAND Flash ■ On-board 2.4GHz radio, up to 1147Mbps physical data rate ■ Support 11ax TX Beamforming ■ Support 11ac/ax MU-MIMO DL and UL ■ Support OFDMA DL and UL ■ Tri-band support with 5G SBS (4x4/5GHz + 4x4/5GHz) + 4x4/2.4GHz ■ Supports Dynamic Frequency Selection (DFS)
Parameter | Rating | Unit | Operating Temperature Range | -20 to +70 | oC | Storage Temperature Range | -40 to +90 | oC | Operating Humidity Range | 5 to +95 (non-condensing) | % | Storage Humidity Range | 0 to +90 (non-condensing) | % |
Symbol
| Parameter
| CPU
| Qualcomm Atheros Quad Core ARM Cortex 64-bit A53 Processor IPQ8074A 2.2GHz CPU
| CPU Frequency
| Derived from Qualcomm Atheros AP.HK01
| System Memory
| 1GB (2x 512MB) DDR3L 32-bit interface
| Frequency Range
| 2.412GHz to 2.472GHz, 5.150GHz to 5.825GHz
| Modulation Techniques
| OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM
| NGFF Slot for 5G Module
| M.2 (NGFF) “B Key” Socket with PCIe 3.0 interface
| Optional Onboard Modules
| Supports 1x BT module,1x ZigBee module,1x Touch pad connector,1x Audio header,1x LCD display header
| Flash
| NOR Flash: 32MB NAND Flash: 256MB
eMMC: 8GB
| Wireless
| On-board 4x4 2.4GHz MU-MIMO 802.11b/g/n/ax, max TBDdBm per chain
On-board 2x(4x4) or 8x8 5GHz MU-MIMO 802.11a/802.11n/802.11ac/802.11ax, max TBDdBm per chain
12x U.FL connectors
| Reset Buttons
| 2x Hardware reset button, 1x WPS reset button
| DC Jack Input
| 1x DC Jack Connector: 12V, 5A
Interface
| 5x Gigabit Ethernet (1GbE) LAN/WAN RJ45 Port (Auto MDI-X)
1x 10Gigabit Ethernet (10GbE) LAN/WAN RJ45 Port (Auto MDI-X) 1x SFP+ Port
2x USB 3.0 Port
1x Serial Port 12 Pin Connector 1x JTAG 20 Pin Connector
1x micro SD Card Socket
1x M.2 Slot
| LED
| 13x LED indicators, 2 additional LED on Ethernet port
| Power Consumption
| TBD
Wallys Communications (Suzhou ) Co., LTD) is a professional supplier of wireless communication products and has a complete industrial chain in China. Its main business is to design and manufacture the latest industrial wireless products, such as router boards, network interface cards, access points, etc., with a wide range of industrial applications.Our biggest advantage is our independent research and development ability.We can provide one-stop customized solutions according to customers' detailed requirements. Recently, our company launched many new products, such as Antenna (DRA24126ESBE),DR6018-S,DR6018C V01,DR8072 V01,DR40X9,DR9074-6E,DR9074-5G and so on.
