wifi6-IPQ5018-QCN9074-2T2R-2.5G-ETH-port-802.11AX-wallys
512MB DDRL3L System Memory 4MB NOR Flash, 128MB NAND Flash 2x2 On-board 2.4GHz radio,up to 573Mbps physical Data Rate Support BT5.1 Two PCIe2.0 connector can support QCN90xx production
Parameter
| Rating | Unit | Supply Voltage
| 12 | V | Operating Temperature Range
| -40 to +70 | oC | Storage Temperature Range
| -45 to +105 | oC | Operating Humidity Range
| 5 to +95 (non-condensing) | % |
Symbol
| Parameter | CPU
| Qualcomm-Atheros IPQ5018
| CPU Frequency
| Dual-core ARM 64 bit A53 @1.0 GHz processor
| System Memory
| 512MB DDR3L 16-bit interface with 32-bit memory bus design
| Ethernet Port
| 4 x 1Gbps Ethernet Ports or 1X2.5Gbps Ethernet Port;
1 x1Gbps Ethernet Port
| NGFF Slot
| 2 X M.2 (NGFF) “E Key” Socket with MiniPCIe 2.0(For WiFi Module)
| EMMC
| 4G/8G(optional)
| USB /header
| 1x USB 3.0 Port
| POE
| NA
| DC Jack
| 12V power supply
| LED header
| LED for power ,Wifi strength
| Serial Port
| support
| Wireless
| On-board 2x22.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax,max 23dBm per chain
2x IPEX Connectors
| Bluetooth | BT5.1
| Nor Flash
| 8MB
| Nand Flash
| 128 MB
| DDR
| 512MB
| Dimension
| 185mm x 116mm
| Radio TX Specifications(2412MHz-2482MHz) |
Operating Mode | Data Rate | Power | Tolerance | 1 Chain | 2 Chains | 2.4Ghz 802.11ax HE20 | MCS0 | 23dbm | 26dbm | ±2dB | MCS1 | 23dBm | 26dBm | ±2dB | MCS2 | 23dBm | 26dBm | ±2dB | MCS3 | 23dBm | 26dBm | ±2dB | MCS4 | 23dBm | 26dBm | ±2dB | MCS5 | 23dBm | 26dBm | ±2dB | MCS6 | 23dBm | 26dBm | ±2dB | MCS7 | 22dBm | 25dBm | ±2dB | MCS8 | 21dBm | 24dBm | ±2dB | MCS9 | 21dBm | 24dBm | ±2dB | MCS10 | 18dBm | 21dBm | ±2dB | MCS11 | 17dbm | 20dbm | ±2dB | 2.4Ghz 802.11ax HE40 | MCS0 | 23dbm | 26dbm | ±2dB | MCS1 | 23dBm | 26dBm | ±2dB | MCS2 | 23dBm | 26dBm | ±2dB | MCS3 | 23dBm | 26dBm | ±2dB | MCS4 | 23dBm | 26dBm | ±2dB | MCS5 | 23dBm | 26dBm | ±2dB | MCS6 | 23dBm | 26dBm | ±2dB | MCS7 | 22dBm | 25dBm | ±2dB | MCS8 | 21dBm | 24dBm | ±2dB | MCS9 | 21dBm | 24dBm | ±2dB | MCS10 | 21dBm | 24dBm | ±2dB | MCS11 | 19dbm | 22dbm | ±2dB
Wallys Communications (Suzhou) Co LTD develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, mainly for export market, welcome to consult. EMAIL:sales@wallystech.com WEB:https://www.wallystech.com/
