AKM AK4687家庭影院立体声CODEC解决方案
发布时间:2011-9-28 10:26
发布者:Liming
AKM公司的AK4687是具有两路输入选择器和线路驱动器的异步立体声CODEC,ADC/DAC接口能接纳高达24位输入数据,并支持异步操作.24位立体声ADC采用64x过取样,取样频率高达48kHz,线性相位数字抗混淆滤波器,S/(N+D)为83dB,动态范围99dB,而24位立体声DAC采用128x过取样,取样频率高达192kHz,24位8倍数字滤波器,S/(N+D)为95dB,动态范围105dB.主要用在蓝光影碟机, 家庭影院,DTV,数字录音系统.本文介绍了AK4687主要特性, 方框图,典型应用电路图,以及评估板AKD4687-A功能,方框图和电路图与元件布局图. The AK4687 is a stereo audio CODEC with 2-channel input selector and a line driver. The interfaces of ADC/DAC can accept up to 24bit input data and support asynchronous operation. The input range of the pre-amplifier, that supports 3ch stereo inputs, is selectable by external resistors. Both the input stereo selector and output drivers support ground reference 2Vrms In/Output, making it possible to remove AC-coupling capacitors and reducing external parts. The AK4687 has a dynamic range of 99dB for ADC, 105dB for DAC. It is well suitable for digital recording systems, digital TVs, Blu-ray recorders and Home theater systems. AK4687主要特性: Asynchronous ADC/DAC Operation 3:1 Capless Stereo Line Input Selector 24bit Stereo ADC - 64x Oversampling - Sampling Rate up to 48kHz - Linear Phase Digital Anti-Alias Filter - S/(N+D): 83dB - Dynamic Range, S/N: 99dB - Digital HPF for Offset Cancellation 24bit Two Stereo DAC - 128x Oversampling - Sampling Rate up to 192kHz - 24bit 8 times Digital Filter - S/(N+D): 95dB - Dynamic Range, S/N: 105dB - De-emphasis Filter High Jitter Tolerance External Master Clock Input: 256fs, 384fs, 512fs 768fs (fs=32kHz ∼ 48kHz) 128fs, 192fs, 256fs 384fs (fs=64kHz ∼ 96kHz) 128fs, 192fs (fs=128kHz ~ 192kHz) 2 Audio Serial I/F (PORT1, PORT2) - Master/Slave mode (PORT1) - I/F format PORT2: MSB, LSB justified (16/24 bit), I2S PORT1: MSB, LSB justified (16/24 bit), I2S Hardware / I2C-bus Control Operating Voltage: - Digital I/O and Charge Pump: 3.0V ∼ 3.6V - ADC Analog: 3.0V ∼ 3.6V - DAC Analog: 3.0V ∼ 3.6V Package: 48pinLQFP 图1.AK4687方框图 图2.AK4687典型连接图(I2C控制模式, CAD0引脚= “L”,主模式) 图3.AK4687典型连接图(H/W控制模式, MCLK=768fs,主模式) 评估板AKD4687-A AKD4687-A is an evaluation board for AK4687, which is a single chip 24bit CODEC with a 2ch ADC and a 2ch DAC. It is possible to evaluate not only A/D and D/A of the AK4687, but also asynchronous operation characteristics. Also, the board could be connected to a digital’s audio equipment easily with S/PDIF connectors. 评估板AKD4687-A功能: Compatible with 2 types of digital audio interface - BNC (S/PDIF) input/output with DIT/DIR (AK4118A) - 10pin headers for interfacing with external data source Separate power supply or regulator power supply 10pin header for register control 图4.评估板AKD4687方框图 图5.评估板AKD4687略图 图6.评估板AKD4687电路图(1) 图7.评估板AKD4687电路图(2) 图8.评估板AKD4687电路图(3) 图9.评估板AKD4687电路图(4) 图10.评估板AKD4687电路图(5) 图11.评估板AKD4687电路图(6) 图12.评估板AKD4687元件布局图 详情请见: |
