Cirrus CS1601 120W数字PFC控制方案
发布时间:2011-7-1 22:45    发布者:Liming
关键词: Cirrus , CS1601 , 数字PFC
Cirrus公司的CS1601和CS1601H是用于电子镇流器的数字PFC控制器,具有最低的PFC系统成本.控制器工作在可变频率不连续导通模式(VFDCM)和零电流开关,具有最好的THD和最小化磁性元件尺寸.主要用在LED电源/驱动器,荧光灯镇流器和HID镇流器.本文介绍了CS1601和CS1601H主要特性, 方框图, 应用电路图和120W高效PFC演示板主要特性,电路图和材料清单.
The CS1601 and CS1601H are digital power factor correction (PFC) controllers designed to deliver the lowest PFC system cost in electronic ballast applications. The controller operates in a variable frequency discontinuous conduction mode (VFDCM) with zero-current switching (ZCS) optimized to deliver best-in-class THD and minimize the size and cost of magnetic components. The CS1601 operates at switching frequencies up to 70kHz while the CS1601H operates at frequencies extending to 100kHz.
The VF-DCM control algorithm varies both duty cycle and frequency. This spreads the EMI frequency spectrum, thus reducing conducted EMI filtering requirements. In addition, the maximum switching frequency is reached at the peak of the AC input, which allows for use of a smaller, more cost-effective boost inductor.
The feedback loop is closed through an integrated compensation network within the controller, eliminating the need for additional external components. Protection features such as overvoltage, overcurrent, open and short-circuit protection, overtemperature, and brownout protect the system during abnormal transient conditions.
CS1601/1H主要特性:
Low PFC System Cost
Best-in-class THD
Digital EMI Noise Shaping Reduces Conducted EMI
Adaptive Switching Frequency Control Minimizes Boost Inductor Size
High Efficiency Due to Zero-current Switching
Integrated Feedback Compensation Simplifies System Design
Comprehensive Safety Features
• Undervoltage Lockout (UVLO)
• Output Overvoltage Protection
• Cycle-by-cycle Current Limiting
• Input Voltage Brownout Protection
• Open/Short Loop Protection for IAC & IFB Pins
• Thermal Shutdown
Pin placement similar to traditional boundary mode (CRM) Controllers
CS1601/1H应用n
LED Power Supply/Driver
Fluorescent Ballasts
HID Ballasts
图1. CS1601/1H方框图
图2. CS1601/1H应用电路图
CS1601 120W高效PFC演示板
The CDB1601-120W board demonstrates the performance of the CS1601 digital PFC controller as a standalone unit. This board is 95% efficient at full load, and has been tailored for use with a resonant second stage to power up to two T5 fluorescent lamps for a maximum output power of 108W. A resonant second stage driver efficiency of 94% is assumed for this application.
120W高效PFC演示板主要特性:
Line Voltage Range: 108 to 305 VACrms
Output Voltage (VLINK): 460V
Rated Pout : 115W
Efficiency: 95% @ 115W
Spread Spectrum Switching Frequency
Integrated Digital Feedback Control
Low Component Count
图3. 120W高效PFC演示板外形图
图4. 120W高效PFC演示板电路图
120W高效PFC演示板材料清单:
详情请见:
http://www.cirrus.com/en/pubs/proDatasheet/CS1601H_PP6.pdf
http://www.cirrus.com/en/pubs/rdDatasheet/CDB1601-120W_DB3.pdf
本文地址:https://www.eechina.com/thread-70402-1-1.html     【打印本页】
1770309616 发表于 2011-9-28 00:18:45
详情请见:
CS1601H_PP6[1].pdf
1005.66 KB, 下载积分: 积分 -1
CDB1601-120W_DB3[1].pdf
1.8 MB, 下载积分: 积分 -1
  • 我们是Microchip
